do cheaper cd-rs work just as good as the more expensive ones. i have been looking on the net and found some good prices, i went to googlegear.com and thay Googlear.com CD-Rs 25 pck for 3.99. i am just using cds until dvd recording becomes affordable. i use them for recording tv shows i have recorded. not vcds but regular cds. thanks for any help.
Bob
They will work, how good they will work depends on your DVD Player, and your CD Burner, and on alot of aspects, but theoraticly they should work.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
They work, but for how long on the cheap ones is questionable. Also the better ones have a scratch resistant surface which is worht getting if your going to use that disc a lot or keep it for a long time.
i dont use them that much after i burn them. and i am also really careful with my burned cd, have bery few that are scratched at all.
Newbie Video Quality Question
By tabutcher in forum Newbie / General discussionsReplies: 3Last Post: 24th Jan 2011, 22:48 -
I have a question how to get hd quality on a tuner
By sdavis in forum Capturing and VCRReplies: 5Last Post: 16th Dec 2008, 16:52 -
By Augie5390 in forum Video ConversionReplies: 24Last Post: 10th Oct 2008, 19:35 -
Question about Quality between I-P-B frame
By Starkian in forum Newbie / General discussionsReplies: 5Last Post: 12th Jul 2008, 02:52 -
DV to dvd quality question
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Nov 2007, 03:12
