Thats the confusing part. If the setting for PAL in the menu worked, couldn't you play PAL DVD's without a hack? When I tried it, the TV picture kept rolling and I had to set it to NTSC to stop it which wasn't easy to do.Why is there a choice for it in the menu when it can't be used.Originally Posted by jagabo
Results 31 to 60 of 66
Region coding and PAL/NTSC format are different things. The DVD world is broken down into several regions. Players are not allowed to play DVDs from other regions, regardless of whether they are PAL or NTSC. Region free hacks allow a player to play discs from other regions.Originally Posted by Katiemay
http://en.wikipedia.org/wiki/DVD_region_code
Whether a player can play PAL or NTSC, or convert from one to another is a separate issue. -
I'm sorry, I didn't state it clearly. The region code only determines whether the player is allowed to play the disc. Whether a player has the ability to play PAL or NTSC or convert from one to another is a separate issue.Originally Posted by Katiemay
Yes, I knew the DVD world is broken down into various regions, and players are not supposed to play DVD's from other regions. This being the case, I wondered why the DVP642 even has a choice of PAL in the player menu. Its not needed in an NTSC player. But maybe its because the DVP642 is sold in countries who use PAL, and Philips use the same menu for all countries.Originally Posted by jagabo
You'll go bonkers if you dig too deep into all of this...Originally Posted by Katiemay
Not all players can do what your player can do....that is convert
"on the fly" between PAL and NTSC...consider yourself lucky and move on.
OK...now it gets weird....without a region hack on your player...even your player
would spit out (not literally but you know what I mean) a factory made/pressed
disc from another region....it would not even allow you to play it.
So now lets say that you have a player that does NOT convert on the fly but is
hackable to ignore region codes. You hack the player. The player will now "recognize"
the disc...but if it is a PAL disc you either won't be able to see it OR it will show up as
black and white on your NTSC television...simply because the TV cannot understand
the PAL signal.
OK....now an even more strange scenario.
Any one of us here can create a homemade DVD that is Region 1...but
in PAL format. (Region 1 is notoriously NTSC as you have found out).
A player that cannot be hacked to ignore region codes will recognize
the disc but your TV will not understand the PAL format.
We can also create a Region 2(or 4) homemade DVD that is in NTSC
format....again completely backwards to what is normal since regions
2 and 4 are notoriously PAL. Your television would easily be able to understand
it's native NTSC signal....but without a region hack on your player...you won't even
get to "first base" so to speak and the player will reject this disc that is not from
it's region.
Crazy huh?
I even have a few commercial DVD releases from the UK that are PAL but region free.
Note that some regions include both PAL and NTSC countries. -
Not if you know all about these things - but I don't.Originally Posted by hech54
"On the fly" in this context means converting PAL to NTSC while playing the disc. As opposed to "offline" on a PC where you rip the DVD (copy it to the hard drive), convert PAL to NTSC, and burn a new DVD.
Katiemay,
This is getting way too complicated for what you originally asked.
In order to play your PAL DVDs and any other DVDs that are not Region 1 on your DVP 642/37, you'll need to do this...
1. Make sure the video setting on your DVD player is set to NTSC. (This means that no matter if the disc you want to play is PAL or NTSC, your player will always output NTSC so that you can see it properly on your TV.
2. Apply the region hack shown ealier in this thread. (This part allows you to play DVDs from other regions regardless of whether they are NTSC or PAL)
Doing these two things will allow you to watch any DVD on your NTSC television no matter what part of the world it came from.
Edit... Sorry. Looks like you were actually just looking for a way to explain to someone else how you can play PAL, non region 1 DVDs on an NTSC TV. I think you're well on the way to forming an answer. -
This seams to be going around in circles, so I'll try and make it plain.
The PAL/NTSC setting only affects what your DVD players outputs to your TV, so if you have a PAL only TV you set it to PAL, if you have an NTSC only TV you set it to NTSC, if you have a TV that can accept both, you can set it to anything you like. You have an NTSC TV so setting the output to PAL caused it to roll.
North American DVDs are Region 1, European are Region 2. Region 1 DVS are NTSC, Region 2 DVDs are mostly PAL although some are NTSC as Japan is also in Region 2 but uses NTSC.
The DVD player can play either NTSC or PAL discs and can output PAL or NTSC but the Region coding means it can only play Region 1 discs. The hack takes off the Region coding. It could already play PAL discs, it's just that it could only play Region 1 and there are no Region 1 PAL discs.
Edited to add that it looks like Rowman can type faster than me...... -
Yes, my first message which started this thread explained what I wanted to know and why. I applied a hack for my North American Philips DVP 642 DVD player 8 months ago, from instructions from the hack forum. I've played 10 PAL movies since then and they all play perfectly. I started this thread to ask a couple of questions and got more information and more involved as I went along which was fine with me. It was interesting. Jagabo, gadget guy,hech84 and others answered my questions and have been very patient and helpful. I understand most things said here except for a few things. Its been a good experience and I learned a lot. ThanksOriginally Posted by RowMan
I didn't know there were any TV's which accept both PAL and NTSC. Would they be North American TV's? Not sure what you mean by "Edited to add that it looks like Rowman can type faster than me.... " - unless you mean that you were going to say some of the same things as Rowman. Thanks for the explanations.Originally Posted by Richard_G
Your DVD player wouldn't play the PAL disk before the hack because the PAL disk wasn't Region 1.Originally Posted by Katiemay
Your DVD player also wouldn't play an NTSC disk before the hack if it wasn't Region 1 (such as a Japanese NTSC Region 2 DVD).
(Oh I'm waaaay too slow - but it IS 4am here) -
Most European TVs can play both PAL and NTSC. Because Region 1 includes both Europe (PAL) and Japan (NTSC).
My DVD player wouldn't play PAL before the hack because my DVd player IS Region 1.Originally Posted by KBeee
My DVD player plays NTSC disks without a hack becuase it IS region 1. So not sure what you mean above. I am in Canada, therefore NTSC, region 1. -
I didn't know that most European TV's can play PAL and NTSC.I thought they just played Region 2 (PAL) movies only, same as Region 1 is NTSC only. That could be why the menu in Philips DVP642 has a choice of either NTSC or PAL, so they both can use the same menu. But about Japan above, you lost me there. You said above that Region 1 includes Japan (NTSC). Japan is Region 2 flor DVD movies.Originally Posted by jagabo
You still don't seem to understand. It's entirely possible for a region 1 DVD to contain PAL video. Region codes and PAL/NTSC are completely unrelated.Originally Posted by Katiemay
I didnt' really think much about that. I have only been interested in NTSC - Region 1 DVD movies ( North America) and PAL being Region 2 (UK) because UK PAL DVD movies are all that I am interested in, besides North America.Originally Posted by jagabo
Region 2 also includes Japan, which is NTSC. I am in Region 4, and we get a number of Region 2,4 discs (both regions set on the disc) so they can be released both here and in the UK, but we also get a number of Region 4 marked discs that are NTSC simply because the studio can't be arsed creating a PAL master. I dare say that the same happens in the UK.
Read my blog here.
It seems a bit confusing to me, but I guess you're used to it. It would be easier for everybody if they just made all DVD's playable in any country. Many people use hacks and other ways to see other region DVD's anyway.Originally Posted by guns1inger
The Region coding and the format are two different things. The differences in format are historical, NTSC was invented in the US and adopted there. The rest of the world decided that the quality wasn't good enough so went with PAL.
Region coding is an invention of Hollywood. The idea is that many films have different release dates in different countries. By using the Region coding they could release a movie on DVD in the US and those of us in Europe wouldn't be able to watch it before it was released, at a later date, over here.
All it does is create confusion and, as you say, anyone with any sort of interest will use a hacked or multi-region player anyway. It has become even sillier in recent years as virtually all DVD players sold in Europe are multi-region and don't need a hack (as they are all Chinese manufactured and are intended for all markets). Those same players sold in the US will have been crippled before being shipped.
With the advent of internet shopping, if I want a DVD that hasn't been released here yet, so isn't available from amazon.co.uk, I just go to amazon.com and buy it from the US instead! -
Regions are ineffective. Copying a disc removes them (because most rippers strip it out). The hard part is a player that will play PAL to an NTSC television, but that's less of an issue since most all Chinese DVD players do both. Most players are now made in China. PAL sets can all handle an NTSC signal in quasi PAL-60 format.
I didn't know all DVD players sold in Europe are muti region. Its nice to know how things work outside of N. America. Yes, you can always order a Region 1 DVD from Amazon.com. Which reminds me -I sent a Region 1 DVD movie to a friend in Scotland 3 years ago (not a home made DVD). He said he couldn't view it on his TV when he put it in his DVD player. He didn't say why). I think his TV is a Goodman or something (not sold here) but from what you are saying, he should have had no problem.Originally Posted by Richard_G
Because his DVD player was a region 2 player and you sent him a region 1 disc. The region code is just a number on the disc. If the player doesn't like the number it refuses to play it.Originally Posted by Katiemay
[quote="jagabo"]
Because his DVD player was a region 2 player and you sent him a region 1 disc. The region code is just a number on the disc. If the player doesn't like the number it refuses to play it.[/qOriginally Posted by Katiemay
My friend asked me to send him a Region 1 disc because he thought it should work on his DVD player which he said was a multi region player and could play any region discs. And Scotland is the UK and part of Europe, and Richard is also in the UK, and Richard says above: "It has become even sillier in recent years as virtually all DVD players sold in Europe are multi-region and don't need a hack (as they are all Chinese manufactured and are intended for all markets" -Am I wrong again? -
Either his player wasn't really region free, or it was one of the few European players that couldn't play NTSC. Or maybe his player could play NTSC but it was set output an NTSC signal, or a PAL 60 signal, which his TV couldn't sinc to.Originally Posted by Katiemay
I don't know of any new PAL kit that isn't multi-format and won't play both PAL and NTSC and output a native signal if asked. Same for TVs. That said, many manufacturers still default the PAL players to PAL output rather than native output, which is annoying.
While pretty much all players are capable of being region free, some manufacturers (mostly brand names, not no-names) do have a range that are region locked, with the resellers providing information on how to unlock them. You will often find the region free version sitting next to them on the shelf anyway, but they still try sell region locked versions - go figure.Read my blog here.
jagabo probably hit the nail on the head. The DVD player is almost certainly region free and will be able to play both PAL and NTSC discs. However, you remember ealier in the thread there was mention of setting the output from the DVD player to PAL, NTSC or AUTO? By default they are usually set to AUTO. In this case they output whatever format the disc is. In AUTO, play a PAL DVD nad it outputs PAL, play an NTSC DVD and it outputs NTSC. Now with most TVs this wouldn't be a problem but......Originally Posted by jagabo
We are talking about a Goodmans here. Goodmans is a brand that used to be a traditional British owned company, now it is a name applied to the cheapest, nastiest, bottom of the pile TVs in production and only made for the UK market. Consequently, they are, or at least were, about the only brand of TV you could buy that couldn't deal with NTSC. I mean, to be able to cope with an NTSC input might have involved an additional 3 or 4 components and would have increased production cost by 10p or so. Just not worth the extra expenditure!
Had he changed the output setting on his DVD player to PAL, it would have worked!
DVD Player Converts PAL to NTSC
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2011, 19:56 -
Can a tv re-set a region-hacked dvd player?
By Monkey69 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 6th Jun 2011, 12:21 -
Samsung DVD-V6800 hacked but B&W how to fix?
By wetcamelfood in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Jul 2009, 19:26 -
Playing Region Free PAL DVD On Soon To Be Hacked Toshiba HD-A2 Player??
By akthmps in forum Newbie / General discussionsReplies: 5Last Post: 8th Apr 2009, 14:19 -
NTSC/PAL DVD player
By jonas more in forum DVD & Blu-ray PlayersReplies: 24Last Post: 9th Jan 2008, 08:40
