I have been trying for ages to find a way to add some data files (HTML, pitcures, javscript files) on to a disk along with a movie. I currently have the movie on a DVD-R and there is enough space for the data files. But I can't find any software that will let me combine DVD video with ROM data and burn them onto the same disk.
I'm a newbie, so please speak slowly! Can anyone help?
	What dvd authoring/burning software are you using now? You can in for example nero burning rom choose to create a dvd-video and add the video_ts to the video_ts folder and then add the data files to another folder.
	Whjat a great thing it is to know what you are talking about! You are awesome, thank you Baldrick
 Only one problem remains - the new DVD I've created has a label which has truncated my desired 22-character Volume Label (which I had entered into the correct field prior to burning) to 15 characters. Is this a limitation of Nero Burning ROM?
 PS I had been using Roxio but have had many problems with it on all kinds of issues.
	I believe that's a limit of the type of file system you are using. But you can select Level 2 which allows 31 characters. However some players may not be able to display them all.
	Ahh .. just saw this sites guide to video structure.
 So the concept is that if all video files are in the video_ts folder, then the DVD player is happy. All other files can simply be read by a PC.
 I have been wanting to do the same thing, except want to do this with the Sony VRD-MC5 burner, and put JPEG's on before I finalize .. I doubt it will let me. Any comments?
  Burning avi/mkv/whatever files as a BD-R/RE data disk for my Blu-Ray playerBy Braindrain in forum Authoring (Blu-ray)Replies: 8Last Post: 25th Jul 2014, 08:13
  Bluray player calling blueray disk "data disk" and saying no video filesBy jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 22:06
  How do I make a dvd data disk from these vob, bup, and ifo files?By DHarry in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2011, 05:23
  combining .VOB files for DVD player diskBy jboyd in forum ffmpegX general discussionReplies: 2Last Post: 12th Apr 2008, 07:39
  AVI capable player not showing all files on data diskBy Seeker47 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 22:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
