I am using TMPEGnc to convert AVI files to MPEG files to put on a DVD for some reason not long ago the program stopped working, saying all my AVI files are no longer supported. Even the ones that I had converted to MPEG before. Not sure what the problem is here.
Please give us more information,
tmpgenc xpress or tmpgenc plus?
have you installed any codecs packs or other video software? -
I see The Monkees has the same problem as me. I have a thread here with a similar title. Hope we can get it solved.
I'm not really sure, it's just called TMPEGnc it doesn't say anything else. I got it a long long time ago, and don't really remember. Also the Direct Show Multimedia Reader is at the top priority.Originally Posted by Baldrick
Actually I figured it out. I went into the Enviromental Settings and just reset the settings and now it works fine.
MKV file not supported on Cello 3D TV
By sjpriest79 in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2011, 18:39 -
Break! File not supported!
By kramboa in forum DVD RippingReplies: 11Last Post: 7th Nov 2009, 09:31 -
Avi not divx-supported size?
By chirufan in forum SubtitleReplies: 21Last Post: 8th Mar 2008, 05:35 -
Converting from flv to any file supported by quicktime
By alanswartz in forum ffmpegX general discussionReplies: 6Last Post: 24th Feb 2008, 19:23 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 12:07
