Results 1 to 9 of 9
  1. We have purchased a new PC and installed Windows Vista. But our Old DVD writer failed to perform in the new system.
    So we purchased a new Sony DRU-190A with Vista support and installed it.
    When we tried to burn DVD we get the following error message.
    Can someone who is familiar with this kind of error, figure out what went wrong?
    Any help would be sincerely appreciated.
    Caching of files started
    Caching of files completed
    Burn process started at 2x (2,770 KB/s)
    Quick format DVD-RW
    Logical unit not ready, operation in progress
    I: SONY DVD RW DRU-190A
    Could not perform start of Disc-at-once
    Burn process failed at 2x (2,770 KB/s)
    Nero Error Log:
    Windows XP 6.0
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 6/11/2007 8:36:34 AM
    NT-SPTI used
    Nero Version: 7.5.14.6
    Internal Version: 7, 5, 14, 6
    (Nero Express)
    Recorder: <SONY DVD RW DRU-190A> Version: 1.62 - HA 1 TA 0 - 7.5.14.6
    Adapter driver: <IDE> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <SONY DVD RW DRU-190A >Version: 1.62 - HA 1 TA 0 - 7.5.14.6
    === Scsi-Device-Map ===
    === CDRom-Device-Map ===
    SONY DVD RW DRU-190A I: CDRom0
    TSSTcorp CD/DVDW SH-W162C J: CDRom1
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE : 0
    Physical memory : 1012MB (1037244kB)
    Free physical memory: 486MB (498224kB)
    Memory in use : 51 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    1.2.2008
    ISO compilation
    10:04:20 PM #1 Text 0 File SCSIPTICommands.cpp, Line 411
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    10:04:20 PM #2 Text 0 File Isodoc.cpp, Line 6517
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : FALSE
    Multisession : TRUE
    Multisession type: : Start multisession
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    10:04:20 PM #3 ISO9660GEN -11 File Geniso.cpp, Line 3341
    First writeable address = 0 (0x00000000)
    10:04:20 PM #4 Text 0 File Burncd.cpp, Line 3490
    Turn on Disc-At-Once, using DVD media
    10:04:20 PM #5 Text 0 File DlgWaitCD.cpp, Line 307
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 1228319 (272:57.44, 2399MB)
    10:04:20 PM #6 Text 0 File DlgWaitCD.cpp, Line 319
    Write in overburning mode: NO (enabled: CD)
    10:04:20 PM #7 Text 0 File DlgWaitCD.cpp, Line 2940
    Recorder: SONY DVD RW DRU-190A, Media type: DVD-RW
    Disc Manufacturer: RITEKW - 01
    Disc Application Code: 64, Disc Physical Code: 214
    10:04:20 PM #8 Text 0 File DlgWaitCD.cpp, Line 493
    >>> Protocol of DlgWaitCD activities: <<<
    10:04:20 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 792
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 1228320 (1228320) = #1228320/272:57.45
    relocatable, disc pos for caching/writing not required/ required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1228320 blocks [I: SONY DVD RW DRU-190A]
    10:04:20 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
    Prepare [I: SONY DVD RW DRU-190A] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc not fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2515599360, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 1228320 | 0 | 0x00
    1228320 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    10:04:20 PM #11 Text 0 File SCSIPTICommands.cpp, Line 209
    SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
    10:04:20 PM #12 Text 0 File Burncd.cpp, Line 4263
    Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
    10:04:20 PM #13 Phase 24 File dlgbrnst.cpp, Line 1760
    10:04:21 PM #14 Text 0 File Burncd.cpp, Line 4382
    Cache writing successful.
    10:04:21 PM #15 Phase 25 File dlgbrnst.cpp, Line 1760
    10:04:21 PM #16 Phase 36 File dlgbrnst.cpp, Line 1760
    10:04:21 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2712
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    10:04:21 PM #18 Text 0 File DVDMinusRW.cpp, Line 262
    Perform 'Quick Format' (type 15h) to set disc in 'Restricted Overwrite Mode'.
    10:04:21 PM #19 Phase 136 File dlgbrnst.cpp, Line 1760
    Quick Format DVD-RW
    10:08:23 PM #20 SPTI -1169 File SCSIPassThrough.cpp, Line 179
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1169)
    Sense Key: 0x02 (KEY_NOT_READY)
    Sense Code: 0x04
    Sense Qual: 0x04
    CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
    Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 04 00 80 FF FF
    10:08:23 PM #21 CDR -1169 File ThreadedTransferInterface.cpp, Line 1750
    10:08:23 PM #22 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1750
    10:08:23 PM #23 SPTI -1169 File SCSIPassThrough.cpp, Line 179
    Sense Code: 0x04
    Sense Qual: 0x04
    CDB Data: 0x55 10 00 00 00 00 00 00 3C 00 00 00
    Buffer x06150440: Len x3c
    0x00 00 00 00 00 00 00 00 05 32 01 C4 08 00 00 00
    0x00 00 00 00 00 00 00 96 00 00 00 00 00 00 00 00
    0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    10:08:23 PM #24 Text 0 File ThreadedTransfer.cpp, Line 269
    Pipe memory size 83836800
    10:08:23 PM #25 Phase 38 File dlgbrnst.cpp, Line 1760
    10:08:23 PM #26 Text 0 File SCSIPTICommands.cpp, Line 254
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    10:08:23 PM #27 SPTI -1169 File SCSIPassThrough.cpp, Line 179
    Sense Code: 0x04
    Sense Qual: 0x04
    CDB Data: 0x1B 00 00 00 02 00 00 00 00 00 00 00
    10:08:23 PM #28 SPTI -1169 File SCSIPassThrough.cpp, Line 179
    Sense Code: 0x04
    Sense Qual: 0x04
    10:08:23 PM #29 Text 0 File Cdrdrv.cpp, Line 11108
    DriveLocker: UnLockVolume completed
    10:08:23 PM #30 Text 0 File SCSIPTICommands.cpp, Line 411
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    File 'Drivers\ADPU160M.SYS': Ver=6.4.645.100 (NT.051018-1332), size=98408 bytes, created 11/2/2006 3:20:35 PM
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
    Tried burned with something else?
    Try upgrade nero to latest version.
  3. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    Try some other media not -RW
    Did you use an 80 wire IDE cable? Or did you use your old cable. Drive jumpered master or cable select?
    Disconnect your other optical drive.
    Nov 2004
    Las Vegas
    planetx,
    "What went wrong" was:
    Nero told the drive to quick format the -rw disk
    After 4 minutes, Nero asked the drive if it was done yet.
    Even though Nero says the drive answered "Logical unit not ready, operation in progress", what it really said was "Logical unit not ready, format in progress". In other words, the drive hadn't finished the quick format yet.
    Nero decided that if the quick format couldn't complete in 4 minutes, it never would, so it terminated the burn.
    Things you can try:
    If you were doing something else on the computer during the format, try leaving it alone during a burn.
    Try using ImgBurn instead of Nero.
    Try a different disk. If that doesn't work, either try a different brand of -rw, or try +rw.
    If that doesn't work, there is a hardware problem (drive, cabling, etc). In that case, someone else here should be able to help you.
  5. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Disable:
    "Multisession : TRUE
    Burning mode : DAO"
    Also, that DVD-RW used is cheapo stuff. Full format it first using NOT nero, but imgburn etc.
    Is the burner in DMA mode?
    *** Now that you have read me, do some other things. ***
  6. Thanks everyone for all the valuable suggestions.
    Sorry I'm really quite a novice in these things. How to determine if the burner is in DMA mode in vista?
    As suggested by you I formatted a fresh disc with imgburn and attempted to burn a DVD. I get the following error message with imgburn
    EDITED: I figured how to determine if the burner is running in DMA mode. The enable DMA mode box is already enabled!
    Nov 2004
    Las Vegas
    planetx,
    Given just the error message, all I can tell is that ImgBurn told the drive to read the first sector, but the drive said it couldn't because the first sector was past the end of the disk. Since ImgBurn was trying to read, the error must have occured at the start of Verify, which follows writing. That would indicate that the problem is either the media or the drive.
    If this disk is the same kind as was used in the log you posted earlier, try a different make of -rw, or try +rw. You could also try using a standard dvdr +/- (not rewriteable). If you can determine that it's not a media problem, the only thing left is your new drive is the problem.
  8. I'm still unable to fix the problem. I tried out all possible things. Yesterday I even uninstalled nero and tried to install a different version; tried using both Nero 8 and Nero-7.8.5.0. Latest update is that apparently the files gets burned and I even get the message "Burn process completed successfully" but when I click open to view the files on the disc I could see nothing. The disc is empty. Please help.
    Nov 2004
    Las Vegas
    planetx,
    That's not surprising. That's what ImgBurn was complaining about in the error message you posted earlier.
    I'll try explaining what's going on in a different way:
    The software (Nero or ImgBurn) is telling the drive to write the data to the disk in a continuing conversation between the software and the drive. At each step, the software tells the drive to do something, and the drive is answering back "Okay, I'm done with that step", so the software instructs the drive to do the next step, and so on. At each step, the drive believes it was successful in accomplishing what it was told to do, because that's what the drive is telling the software. However, at the end of the burn, there isn't anything really on the disk.
    That means that even though the drive was going through the motions, nothing was actually being written to the disk. There are only two reasons why that would occur:
    1) The disk is either defective, or the drive isn't able to use the disk.
    2) The drive is defective.
    To rule out the possibility that the problem is #1 above, get even one Verbatim dvdr (not rewritable) disk, and try burning that. It doesn't matter whether the disk is +R or -R, just that it's Verbatim and not rewritable.
    If that works, then the drive is fine, and you need to find media that works in that burner.
    If it doesn't work, the drive is defective. Since it's a new drive, exchange it for a new one.
