I really canīt solve this guys. Itīs impossible for me to add subtitles to an avi file with ffmpegx without getting the already famous: sh: line 1: /Library/ Application Support/ ffmpegX/ mplayer: cannot execute binary file
This one appears when I click for viewing the subtitles preview. Of course subtitles wonīt come up when I encode the file. I installed the application and the other three files just fine. Any ideas?
It means (at least) mplayer is not installed as it should be.
Did you download ffmpegXbinaries20060307.zip and unzip the archive? Did you use the Locate buttons to browse to the respective files on your desktop?
It should look something like this:
Note how the download URLs on the left side are replaced by the local location of the downloaded files, as I have indicated in the green boxes.
Enter your admin password and hit "Install".
After that, try quitting and relaunching again to see if the installer-window stays away this time. (It should.)
Items in red were faulty or not present, and need to be installed. Items in black are okay and can be unchecked.
Adding subtitles to a DVD in Linux
By MrProsser in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2008, 02:14 -
Problem adding subtitles to DVD
By makoto in forum ffmpegX general discussionReplies: 3Last Post: 15th Sep 2008, 14:25 -
Adding Subtitles to DVD
By ukrainka in forum SubtitleReplies: 2Last Post: 31st Jan 2008, 16:33 -
By RealTelstar in forum SubtitleReplies: 1Last Post: 28th Sep 2007, 15:36 -
By RealTelstar in forum SubtitleReplies: 2Last Post: 28th Sep 2007, 15:35
