Which DVD burner is compatible with Verbatim DL?
I am going to get a new one since I got two coasters and this burner won't burn them. I am just going to go to walmart or something.
Results 1 to 10 of 10
This is a block of text that can be added to posts you make. There is a 255 character limit
most dvd burners are dual layer. get a PATA PIONEER 115 or SATA drives SAMSUNG S203B or LGH62L.
Rather than recommend specific burners, I'd like to point out that there could be other things at work here.
1) You might have burned with Nero, which is a bad idea. We recommend using ImgBurn for all DL burning. Nero doesn't always set the layer break correctly and it may just simply not work for some burns. We had a post about the latter earlier this week.
2) DVD-R DL (note that minus sign) is VERY VERY different from DVD+R DL and if you neglected to mention that you are using DVD-R DL discs, all bets are off. Only ImgBurn can correctly burn these discs and even then it may require some special configs by you to get it to work correctly.
Your burner, which you should have listed, may need a firmware upgrade to burn DL media. You might try that before you buy a new drive. Although I don't hear a lot about them, I have an older NEC drive that just works like a champ for me. -
The new Sony drive started the burn process, but later gave me an error.
This is now my third coaster.
I 13:36:06 Writing Layer 0... (LBA: 0 - 1931215)
I 13:55:59 Writing Layer 1... (LBA: 1931216 - 3862428)
W 13:56:20 Failed to Write Sectors 1931824 - 1931855 - Write Error
W 13:56:20 Retrying (1 of 20)...
W 13:56:20 Retry Failed - Invalid Address For Write
W 13:56:20 Retrying (2 of 20)...
W 13:56:20 Retrying (3 of 20)...
W 13:57:03 Retry Failed - Invalid Address For Write
E 13:57:04 Failed to Write Sectors 1931824 - 1931855 - Write Error
I 13:57:04 Synchronising Cache...
I 13:57:05 Closing Track...
I 13:57:14 Finalising Disc...
W 14:00:05 Potential 'WaitImmediateIO' Deferred Error - (0/2) - Session Fixation Error Writing Lead Out
E 14:00:11 Finalise Disc Failed! - Reason: Session Fixation Error Writing Lead Out
I 14:00:11 Finalising Disc (Last Attempt!)...This is a block of text that can be added to posts you make. There is a 255 character limit -
Two questions - at what speed were you writing, and when did you get the Verbatim discs? If you got them recently, check the "Made in" label. A lot of the recent ones were made in India, and there have been nothing but complaints about them.
Also, what is the exact model of the burner you got? -
And even though you just bought it, you may still want to check for new firmware for it. It's possible a new firmware version came out after the drive left Sony.
Jim -
SONY no longer makes DVDwriters. They have relabeled several different makers drives of varying quality.
I'd consider returning this drive and buying something you know the manufacturer of. This means not buying SONY, IOMagic or any other company which does not make what they sell. It gives you a better chance of prompt firmware updates, and technical support. -
At the recommendation of Budz (thanks again !), I bought a Samsung SH-S202G (IDE interface) and it writes perfectly when using the Verbatim dual-layer DVD-Rs. I have no experience with SATA burners, but if you are considering IDE drives as well as SATA, the SH-S202G should make you happy.
Good luck with your purchase. -
Right now they're all Samsung drives, which are about on par with Pioneer (the best drive) for burn/rip/read quality (Pioneer still reads/rips a bit better, but BURNING is the most important aspect!).Originally Posted by oldandinthe wayWant my help? Ask here! (not via PM!)
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer DVD Burner Use
By Aristocles in forum Newbie / General discussionsReplies: 4Last Post: 15th Oct 2009, 02:11 -
Dual Layer writing not working properly
By uniks in forum Newbie / General discussionsReplies: 9Last Post: 5th Mar 2009, 09:37 -
External/Internal dVD-R dual layer burner
By SIRCOOKS in forum ComputerReplies: 6Last Post: 14th May 2008, 12:45 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
