    Feb 2001
    If I just want to cut OUT a small part of a Clip... is'nt there anyway to just cut that OUT liek you do in Phototshop... just makr and delete?
    Do I have to save all the parts I need to then jopin by append?
    That seems likte a pretty "unsmart" way to cut out thing like commercials and stuff!
    Thanx/
    Lars
  2. Banned
    Apr 2001
    Calgary, Canada
    Find the beginning of the section you want to remove, and hit HOME. Find the end of the section you want to remove, and hit END. Then, hit DEL and poof, its gone. Save the avi or fire up the frameserver.
