Hello All, (newbie)
Can you help me please?
Why is it that my burned DVDs (using Roxio 8 from an image file created in Roxio) play great at home on my player but on other players it will skip and/or freeze? These 'other' players work fine with commercial DVDs.
I have upgraded the firmware on the burner and am using a Sony recommended media (TDK +R 16x).
This issue is driving me crazy!![]()
Are there other software programs that will burn image files better?
What is the magic bullet?
Thanks.
Sony VAIO RS430G - P4, Windows XP SP2, 1GB RAM, 500G
Sony DRU-810A USB DVD BURNER with latest firmware v.2f
Radeon 9550 256M 8X AGP video card
Windows Media Player 10
Microsoft Internet Explorer 7
Results 1 to 16 of 16
I would first try different media, www.nomorecoasters.com .
Then try different authoring/converting/burning software, Tmpgenc DVD Author, Ulead DVD MovieFactory, etc. -
Your Roxio software and Sony recommended media (TDK +R 16x) are not held in high esteem here. Try Baldrick's suggestion.
I need to be able to use the image files that I have. What 'other' suggested programs will burn from image?
I found this:
IMG is an image/iso of a DVD, CD, Floppy. Burn it to a DVD or CD with DVD Decrypter or extract the content with Isobuster or mount it as a virtual DVD/CD unit with Daemon Tools. -
Use ImgBurn to burn. It is the burning part only of DVD Decrypter, updated and kept current, from the same author.
That, and making sure you have the latest firmware for your burner (which you said you had), and using good quality media as Baldrick and bendixG15 mentioned will go a long towards getting good burns. -
I see at http://www.nomorecoasters.com/ that TDK is a First Class (A) quality. Isn't that OK?Originally Posted by bendixG15
Only if the Media ID is TDK. This is not the "brand" as printed on the label/box/whatever.Originally Posted by DiverDennis
Most recommended discs are Verbatim and Taiyo Yuden.
As for the "hiccups", it could be either the media or the "hiccups" exist on the authored files. ImgBurn just feeds the bits to the burner to burn onto the disc, it won't have caused the "hiccups". -
Ah ha. Now I'm getting it. I downloaded DVD Identifier and will check the media to see if it is the real deal. Thanks.Only if the Media ID is TDK. This is not the "brand" as printed on the label/box/whatever. Most recommended discs are Verbatim and Taiyo Yuden.
If you are getting hiccups it could also be an overloaded system which is underrunning the burner during the write. Make sure you are not running other programs while burning.
Some people get better results by reducing the burn speed, but don't burn 16x media at 4x or below - more problems may kick in. -
OK. I always burn with no other apps running.Originally Posted by oldandinthe way
Thanks for the tips......reducing the burn speed, but don't burn 16x media at 4x or below - more problems may kick in. -
I checked all the media I've been using.....it's all crap! The best I have is 2nd class. Gonna get some Sony class 1 and monitor the results.
Hopefully your help will keep me from going crazy
Thanks you.
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
Dealing with consistant mic noise
By HDClown in forum RestorationReplies: 10Last Post: 29th Apr 2010, 19:39 -
Music sound playback is greater than word sound playback
By shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 13:09 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
playback on tv
By andyluong99 in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 16:08
