I captured an HD tv show from my DVR, and convereted to an MPG using HDTV2MPEG (v.1.11.93).
The resulting MPEG is fine, and the audio is in synch. However, when I burn it to a DVD (either using NERO or Sonic MyDVD), the audio is severely out of synch (almost a complete second).
Any suggestions?
Use a authoring program that doesn't change or re-encode the video before burning like Nero too often does.
If it's DVD compliant, then it shouldn't be re-encoded, just authored and burned. Authoring shouldn't change it, just format it to the DVD structure. You can see the DVD format, structure and specifications in 'WHAT IS' DVD to the upper left on this page.
You should also be able to turn off the re-encoding in Nero. I would try playing the VIDEO_TS folder before burning it to see if the video is in sync. VLC Media Player can do that. You could also try a freeware standalone authoring program like GUI for dvd author.
And welcome to our forums.
audio and video not in synch by a second or two problem
By sabathiel in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2011, 22:45 -
Audio synch problem after IVTC
By avengerevenge in forum AudioReplies: 1Last Post: 15th Feb 2010, 12:34 -
Video/Audio synch problem
By tangomango in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 13:19 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
Audio Synch problem using AviSynch
By spycraft in forum Newbie / General discussionsReplies: 21Last Post: 4th Jul 2007, 05:04
