im wanting to know whats the best program for ripping a DVD to DIVX
thanks
Results 1 to 27 of 27
Actually, those programs require you to have already ripped the DVD to the hard drive; they don't rip the DVD for you. Are you attempting to run AutoGK on an actual (retail) DVD disc?
Off the top of my head, I don't know what programs will rip a DVD for you and automatically convert to DivX/Xvid, but they're probably not as good as ripping the DVD yourself and then feeding the results to AutoGK, or similar.If cameras add ten pounds, why would people want to eat them? -
the DVD isnt retail...hence no Encryption..
I dunno, im new to ripping thats why i asked.. i know how to rip a movie onto the PC... but dunno what to use to convert the VOBs (as 1 structure) to DivX -
Are you converting directly from the DVD? Try copy the DVD to your HDD first.
And read a GUIDE, http://www.divx-digest.com/articles/autogk.html -
why would it make difference if the VIDEO_TS was on Har-drive instead of disc? the disc isnt protected....
well still the same...
have copied all the VIDEO_TS onto drive and when i add the IFO file it says error parsing IFO.....? -
well I think i sussed it.. its not the VIDEO_TS.IFO file.. its the VTS_02_0.VOB (for some reason) and choose the largest RPG....
BUT it encodes into AVI... i want DivX file not DivX encoded AVI -
If you want a Divx container then you need to use either Divx Author or Dr Divx. You will have to use DVd decrypter or VOB2MPG to extract a single video first, then convert.Originally Posted by snadgeRead my blog here.
Rip the DVD with DVD Decryptor in IFO mode. That will give you the main title as a single VOB file. Then use Divx Converter to make a .DIVX file.
But .DIVX files are .AVI files, just renamed. All you have to do to make an .AVI file into a .DIVX file (assuming the video is encoded with the Divx codec) is rename it. .DIVX can contain additional information like subtitles, chapters, menus, etc. but it doesn't have to. -
hmmm thanks huys.... as always very helpful
i have renamed a current AVI i have and yes it works
CHEERS GUYS -
You're saying - You have a player that plays .divx, but refuses to play .avi?
/Mats -
Changing ".AVI" to ".DIVX" doesn't change the container. It just changes the extension, nothing more.
/Mats -
As avi is a subset of divx (or: divx is an extension of avi), renaming a.avi to a.divx works, yes, but it does in no way alter the fact that it is a plain AVI.
/Mats -
ok
which is the fastest program/method to convert a DVD to .DIVX with the best results..?
I would also like to choose the size of the files if possible -
Why this urge to create a divx, as it seems like you seem to be satisfied with the features of avi, as long as it doesn't say ".avi" at the end?
Anyway, guns1inger gave you the answer: https://forum.videohelp.com/topic345246.html#1807470
TDA 3 can be used too.
/Mats -
You've been given the names of several applications that can create .DIVX files.
But if you aren't including menus, chapters, and subtitles, there is no difference between an AVI and DIVX file except the extension. The AVI container (an instantiation of the more general RIFF container) was designed to be extended. So The argument over whether a file is DIVX or AVI is simply a semantic issue. -
yeah just the main movie...
SimpleDIVX isnt working for me..it just creates log files and NFO's
DivX Author seems to work but was gunna take 3-4Hours.. a bit too long I think
DivX Converter seems OK but it doesnt allow to change any settings such as output name & destination..
Where does it stick the output file? -
I think it's a crappy little program. By default it puts its files in the Divx\Movies folder, usually c:\program files\divx\movies.Originally Posted by snadge
The speed of converting to divx is mostly a matter of the Divx encoder settings. What program you use doesn't make as much difference (unless you're doing a lot of filtering).
Looking for 2nd conversion to AVI app that works as standalone?
By Diana (Cda) in forum Video ConversionReplies: 11Last Post: 5th Jan 2012, 16:15 -
Portable app for combining AVI files
By cowboyup910 in forum EditingReplies: 3Last Post: 27th Oct 2011, 02:58 -
App for converting .vob folders/files to DIVX or XVID?
By Newb787 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2011, 14:21 -
AVI,VOB,MPG > WMV * New App
By VirtualDoobMon in forum Video ConversionReplies: 2Last Post: 14th Oct 2008, 19:42 -
AVI to DVD to Burn - All-In-One App Exist?
By quantass in forum Authoring (DVD)Replies: 11Last Post: 2nd Jul 2007, 21:20
