Running XPP, I can't get into my system at all. I keep getting this error:
"STOP:c0000135 {unable to locate component} This application failed to start because CSRSRV.dll was not found. Re-installing the application may fix the problem."
I did a search and found I could boot with my XPP CD. So I changed BIOS and tried booting with my XPP CD, Recovery Console, but don't know how to use command line and/or install the csrsrv.dll from the XPP CD into the systerm32 folder. Or is it another folder I need to install it into? Can someone assist? Thanks.
Oh, and I can't get into safe boot mode either. (edit)
how'd it die is more important than the file. what was the last thing that you were doing before the no-boot. but here is the file.
http://www.dlldump.com/download-dll-files.php/dllfiles/C/csrsrv.dll/download.html
and here are instructions to copy it to the comp.
http://www.filegurus.com/cgi-bin/blah/Blah.pl?b=faqs,m=1100745524--
Thanks for the info, aedipuss. I've decided to just do a fresh re-install, as it's been a veeery long time since the last.
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Again blue screen!!!
By alintatoc in forum ComputerReplies: 10Last Post: 10th Dec 2009, 15:16 -
what's a blue screen?
By aruwin in forum ComputerReplies: 8Last Post: 23rd Sep 2009, 09:56 -
can't install Avisynth due to the devil.dll
By cemman in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2009, 06:18
