My pc monitor just started crapping out. It works for a second then goes black. It will do this repeatedly if you power it off/on.different monitors work fine.this does the same thing on other pcs. should i throw it out?
AnonymousGuest
Could be a bad power supply??? Have you checked the power supply, and video cable? If they're good, then it's going bad.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
This might sound daft, but have you connected the right power supply for that particular monitor? I had this exact problem, because I had confused the monitor power cord with the one for my speakers.
Aspect Ratio Problems (Samsung LCD)
By darkstormrider in forum DVB / IPTVReplies: 1Last Post: 4th Jan 2011, 17:06 -
LCD problems (vertical banding ? )
By snadge in forum DVB / IPTVReplies: 20Last Post: 16th May 2009, 11:17 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 12th Feb 2009, 23:01 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 12:29 -
Sanyo DP32647 LCD TV Picture Problems
By mstpaintball in forum DVB / IPTVReplies: 2Last Post: 29th Aug 2007, 15:04
