When I got my DVRHD box a couple days ago from COx Cable,I hooked it up via the RGB cables. I noticed that on some channels that I could not get the correct aspect ratio (TBSHD being one) on some programmes,they look like they just braodcast a 4:3 picture and expand it to fill the screen.
So I switched over to the HDMI output from the box,and while I think the aspect ratio problem is better,i can no longer control the volume via the Cox remote,whereas I could when i had it hooked up via RGB. (I changed the settings on the remote to do this)
I changed the audio cables to match the HDMI input on the back of the TV. When I go to change the volume,I see the volume indicator appear on screen as it did before,and it moves up and down as it should,but the volume stays the same,and I have to use the TV remote to change it.
Anyone else found this problem? Or is it my TV? I checked the settings,but nothing seems to affect it to get it to work.
The cable box is model Scientific Atlanta 8240HDCand the TV is an HP 52" DLP
thanks
TBSHD is always broadcasting at the wrong aspect ratio. They insist on filling the 16:9 screen regardless of the source AR.
When using an HDMI cable the STB should be sending unmodified audio to the TV -- it then becomes the TV's job to adjust the volume. Program your remote with the proper code for you HDTV. -
Hmm,tried it but no luck.I've tried different combinations of all the settings i can think of,so for now i just changed it back to RGB like it was before.Originally Posted by jagabo
Hopefully there wont be anything on TBS that I want to watch,although I can't understand why the channel is labeled as HD when in fact it is just expanded regular definition,it looks ridiculous. Might as well watch the regular channel ! -
Component (RGB) and HDMI should both output the same to your TV. The only difference would be how your TV is displaying that input (ie: zoom/stretch/etc.)
As for the audio, some cable boxes have control over the audio before it leaves the box (for the RCA outputs) and will display the volume information on the TV. If you are using the HDMI output, then the video and audio are output over the HDMI cable and the volume cannot be adjusted by the cable box(it should stay at line level). You would then need to adjust the volume on the TV itself.Google is your Friend -
Regarding the issue with no variable audio with the use of the HDMI connection. I had the same problem with a Panasonic plasma and a Scientific Atlanta cable box. Find the instructions for your cable box remote control and look in the programming section if it shows programming a volume control "global lock" which is kind of an over-ride. That will allow you to lock the remote to only send volume +/- commands using the TV's infrared code. You can actually set volume control function to any of the components programmed into the remote but you need to set it to TV in this instance. Instead of the cable box controlling volume by variable output, you now are using the TV's internal volume control (better anyway). Now you can use just the cable remote select cable but still adjust volume with that remotes volume button.
Another solution is to set your TV's audio input to analog for the HDMI input and set the cable box to digital dolby or regular old rca audio out and connect rca cables between the box and TV for audio only. You will still have to raise the TV volume sufficiently and then use the cable box remote to adjust the volume with it's variable output. I just tried both ways and prefer the first solution I mentioned above. -
That's not entirely the channels fault. If the original source wasn't recorded in 16:9 then the only thing it can do is display it as 4:3 - or at the worst STRETCH it to 16:9. Fortunately not all hd channels stretch 4:3. I'd rather have an old Seinfeld or Home Improvement rerun in 4:3 then to see them look ridiculous.Originally Posted by culttvguy
The worst thing I hate as I mentioned in a previous thread is not having widescreen movies or even 5.1 audio on a hd channel. I know its more money to broadcast a widescreen or 5.1 audio but that's WHY I PAY FOR HD CABLE!
Oh well at least some do and it can only get better
At least USA broadcasts in widescreen (ok cropped to 1.78 from the original 2.35 but still "somewhat" widescreen) and 5.1. They did the Indiana Jones trilogy in the spring when Indy 4 hit the theaters - those looked awesome.
Now unfortunately the scifi channel is choosey too. The weird thing is they will show widescreen episodes of Stargate SG1 and 5.1 audio but not fully 16:9. It's pillarbared 4:3. So I just use the stretch mode to fill the screen (I own all 10 seasons on official dvd so it's not that big of a deal to me - just annoying).
Don't worry they'll start to get the hang of it as hdtv grows and matures..Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
scientific atlanta cable box explorer 2000
By Darkcast in forum DVB / IPTVReplies: 1Last Post: 13th Mar 2011, 13:49 -
Scientifc Atlanta 3250HD cable box questions
By joecass in forum Newbie / General discussionsReplies: 23Last Post: 27th Apr 2010, 14:31 -
scintific atlanta 2200 cable box
By bammthis in forum Capturing and VCRReplies: 8Last Post: 16th Mar 2010, 00:32 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
Scientific Atlanta 8300 HD/PVR Rogers Cable Recoding Required To Work.
By musicmavern in forum DVD & Blu-ray RecordersReplies: 6Last Post: 8th Aug 2008, 11:52
