I've got some widescreen HD video that I want to capture using Final Cut Pro 6 and a Canopus ADVC-100. However, it's not coming in 16:9. It's coming in 4:3 and letterboxed.
The source is my DVR.
I'm NOT trying to capture as anything more than standard DVD resolution. But, I'd like to have the picture fill my 16:9 TV.
Any ideas?
Results 1 to 11 of 11
The ADVC-100 captures what you feed it. If the feed is letterboxed that is what you will get. You might be able to get the source to output anamorphically.
As mentioned you need to adjust the output on the playback device, if for example you are watching a 16:9 DVD on a 4:3 TV the black bars are added by the DVD player. Setting the DVD player to not letterbox it will provide a full frame of video, looks funny on a 4:3 TV but its really irrelevant if you want to capture the full frame. Encode and author as 16:9.
What travels over the s-video cable is only one thing: interlaced NTSC video in a fixed 4:3 format. Whether that video contains letterboxed frames (the 16:9 source is shrunken proportionally and has black bars added to the top and bottom to fill out the 4:3 frame) or anamorphic frames (the 16:9 video is squashed disproportionately to just fit the 4:3 frame) depends soley on the device putting out that signal.
If you can't convince the device to output anamorphic frames all you can do is take the letterboxed capture, cut 60 lines off the top and bottom (leaving 720x360), and resize what's left back up to 720x480. -
Another possibility is that it was recorded by the DVR as letterboxed? In other words it's possible that it added the black bars to a 16:9 source to begin with, in that case you have a 16:9 movie on 4:3 matte, similar to what Jagboo suggested you would have to capture it then crop.
In any event if you can't get a full frame capture you're better off authoring it as-is and use the zoom on your DVD player. -
jagabo - If I cut off 60 lines at the top and bottom, won't that blur the image?
Cropping and upsizing will blur the image. But that's the only option if you can't get the player to output anamorphically and you want an anamorphic encoding. You will also run into interlaced video issues since you are in an NTSC country. As Thecoalman said, you're probably better off leaving your video letterboxed.Originally Posted by whoisquilty
Then, is there affordable equipment for capturing to FCP using an HDMI connection? I've got a Mac Powerbook G4, so the Blackmagic card (http://www.blackmagic-design.com/products/intensity/) won't work for me.
Not that I'm aware of. The MPAA goes way out of it's way to make sure you can't capture any encrypted HDMI source (like HD-DVD, Blu Ray, cable box, or satellite receiver).Originally Posted by whoisquilty
I'm in the same boat as you. I wish I could capture downconverted HD anamorphically from my cable box via s-video. But I'm stuck with letterboxing since that's all the cable box will put out. -
The only way I've been able to get my cable settop box to output NTSC (480i) widescreen is to digitally route the signal into a D-VHS machine via Firewire. The D-VHS machine fortunately doesnt letterbox ATSC (1080i, 720p) widescreen on downconversion to 480i and out via S-Video.
Capturing issue with Canopus ADVC-110
By nharikrishna in forum Capturing and VCRReplies: 6Last Post: 24th Aug 2011, 12:30 -
Capturing with canopus advc 300
By blacksheepdownunder in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2010, 09:20 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 22:55 -
Question about capturing with Canopus ADVC110
By Endzone in forum Capturing and VCRReplies: 8Last Post: 3rd Mar 2008, 21:42 -
Capturing live TV with Canopus ADVC?
By Deisel Weisel in forum Capturing and VCRReplies: 12Last Post: 11th Jan 2008, 00:57
