  1. Ive got a .mkv file that VLC player usually plays. in this case it gives me the above message and won't play it.
    anything I can do?
    cheers and thanks
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
  2. well Ive solved my own problem by luck alone:
    I opened the file w QT by using 'open with ...' and then QT at the top said done w AutoMKV 0.92 then a web address. after it opened I did a save as and changed the tile a little bit and Im done.
    still would like to learn more about the problem
    cheers
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
