Hello everyone!
I’ve been using mencoder for about a week now and love it! However there is one issue that I just can’t seem to solve during a blood sweat and tear search the past 3 days. For some reason, mencoder is defaulting to 2 channel ac3 when 6 channel (5.1) is desired for encoding movies.
Here is my skinny, I’ve tried two different scenarios as follows.
mencoder dvd://1 -dvd-device /archives/dvds/OFFICE_SPACE/ -alang English -oac alsa9 surround51 -channels 6 -ovc xvid -xvidencopts bitrate=2526 -o "/dev/null"
mencoder dvd://1 -dvd-device /archives/dvds/OFFICE_SPACE/ -alang English -channels 6 -oac copy -ovc xvid -xvidencopts bitrate=2526 -o "/dev/null"
I get the same results for both as follows. Mencoder/mplayer sees both audio streams. When I tried a simple -oac copy I get 2 channels ac3, when I try to force it with -channels 6 it states Unimplemented resampler for mode 0xA -> 6 channels conversion - Contact MPlayer developers! I hope this is something stupid. Did I miss something during compilation?
Any help would be greatly appreciated. Dolby Digital 5.1 is a must for me. If I can't get this to work, I guess I will have to go back to windoz and AutoGK.
MEncoder 1.0rc2-4.1.2 (C) 2000-2007 MPlayer Team
CPU: Intel(R) Pentium(R) D CPU 3.00GHz (Family: 15, Model: 6, Stepping: 4)
CPUflags: Type: 15 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
Option oac: Unknown suboption alsa9
Error parsing option on the command line: -oac
Exiting... (error parsing command line)
There are 3 titles on this DVD.
There are 29 chapters in this DVD title.
There are 1 angles in this DVD title.
audio stream: 0 format: ac3 (stereo) language: en aid: 128.
audio stream: 1 format: ac3 (5.1) language: en aid: 129.
number of audio channels on disk: 2.
subtitle ( sid ): 0 language: es
subtitle ( sid ): 1 language: en
number of subtitles on disk: 2
success: format: 2 data: 0x0 - 0xf8ec3800 No matching DVD audio language found!
MPEG-PS file format detected.
VIDEO: MPEG2 720x480 (aspect 2) 29.970 fps 9800.0 kbps (1225.0 kbyte/s) [V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334 ================================================== ========================
Opening audio decoder: [liba52] AC3 decoding with liba52 Using SSE optimized IMDCT transform Unimplemented resampler for mode 0xA -> 6 channels conversion - Contact MPlayer developers!
Unimplemented resampler for mode 0xA -> 5 channels conversion - Contact MPlayer developers!
Unimplemented resampler for mode 0xA -> 4 channels conversion - Contact MPlayer developers!
Unimplemented resampler for mode 0xA -> 3 channels conversion - Contact MPlayer developers!
Using MMX optimized resampler
AUDIO: 48000 Hz, 2 ch, s16le, 192.0 kbit/12.50% (ratio: 24000->192000) Selected audio codec: [a52] afm: liba52 (AC3-liba52)
xvid: using library version 1.1.3 (build xvid-1.1.3) Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 ================================================== ========================
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred colorspace: Mpeg PES) Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
Try appending the scale filter to your filter list, e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2)) ================================================== ========================
audiocodec: framecopy (format=2000 chans=2 rate=48000 bits=16 B/s=24000 sample-1)
VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
videocodec: XviD (720x480 fourcc=44495658 [XVID])
xvid: par=0/0 (vga11), displayed=720x540, sampled=720x480
xvid: CBR Rate Control -- bitrate=2526kbit/s New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
Pos: 0.0s 1f ( 0%) 0.00fps Trem: 0min 0mb A-V:0.000 [0:0]
1 duplicate frame(s)!
Writing header...
ODML: vprp aspect is 4:3.
Setting audio delay to 0.033s.
Writing header...
Writing header...2f ( 0%) 0.00fps Trem: 0min 0mb A-V:0.003 [0:0]
Addition:
I've also tried to even specify the ID belonging to the 5.1 stream in this case was 129 with -aid. Similar out put which is still 2 channels.
Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE SSE2
AUDIO: 48000 Hz, 2 ch, s16le, 448.0 kbit/29.17% (ratio: 56000->192000)
audiocodec: framecopy (format=2000 chans=2 rate=48000 bits=16 B/s=56000 sample-1)
Writing header...
Writing header...
