Hi All,
Need to hack the region code for Sony DAV FX100W. I found a link explaining how to get to the system menu:
"To get to the system menu on this player, remove discs then turn it ON, while holding Stop and Eject press Volume + (All at the same time)."
But this actually brings the system diagnostic menu and there is no option to change the region code.
Can anybody help?
Thanks in advance,
alex
Most Sony units cannot be "hacked" and the few that can, don't use simple remote codes. Sony units typically support region free out of the box, or they don't.
The procedure above is likely accurate for accessing the system menu, but the hack posted doesn't state any information besides how to access the system menu, so I don't believe it is a true region hack.
Sony is known for their copy protection enforcement, hence the reason why their players cannot be hacked.Google is your Friend
Sony dav-s400
By jdaml in forum Newbie / General discussionsReplies: 0Last Post: 24th Aug 2010, 11:56 -
Not sure about the Sony DAV-HDX265
By onenonly in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2009, 15:34 -
Sony DAV-HDX576WF
By PAME in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Apr 2009, 07:52 -
Sony dav-fr1
By Gerard Russell in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2008, 15:42 -
Sony DAV-DZ230
By TCEkryten in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Dec 2007, 15:59
