    Sep 2007
    Malaysia
    i extracted subtitle from my movie by using subrip. then i installed vobsub to view the file. when i tried to play the movie with subtitle by using real media player, i found out the subtitle is a bit off. can i use virtualdub to fix the problem? or is there any other way to do that? thnx!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    First I would verify playback issues with another media player (MPC or VLC). If the problem still exists, I believe the only solution is to maually edit the timings in the subtitle file.
    Google is your Friend
    Sep 2007
    Malaysia
    thank you
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Use a subtitle editor, like Subtitle Workshop which has various time shift functions you can apply to all subs at once, rather than using a text editor.
