Trying to use WMM 2.1 to edit MPEG files made recording HD & SD TV with a Pinnacle USB Stick digital tuner & its "TV Centre Pro" software.
WMM shuts down or becomes unresponsive either upon importing or placing clips on the timeline or trying to play clips from the timeline.
WMM and mpeg2 = buggy.
You could try change the default mpeg2 decoder with Windows XP Video Decoder Checkup Utility , http://www.microsoft.com/downloads/details.aspx?FamilyId=DE1491AC-0AB6-4990-943D-627E6...displaylang=en . If just one installed then you can try for example ffdshow, powerdvd, windvd, etc.
Or the best solution, use a mpeg editor like videoredo, mpeg video wizard. -
I have to agree with Baldrick. I've recorded many television episodes and old VHS tapes and have always edited with VideoRedo.
It'll import MPEG2 files made from my Hauppauge PVR350 happily.
Trimming commercials and making clips are incredibly easy with a little practice.
...worth every dime...
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
Windows Movie Maker not importing the full video
By Nintendo Fan in forum EditingReplies: 2Last Post: 2nd Jan 2011, 16:40 -
Windows Movie Maker Importing converted files issue
By gmania in forum Video ConversionReplies: 4Last Post: 14th Oct 2009, 05:57 -
Dropped frames when importing Windows Movie Maker video into Magix edit pro
By gom in forum EditingReplies: 1Last Post: 27th Oct 2008, 10:55 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 22:18
