I am using both WMV.vdplugin and MPEG2.vdplugin pluggins for virtualdub.
Both would allow me to edit mpeg and wmv. I since then formated and using the exact same vdub I can no longer edit wmv (mpeg works).
After it goes threw the whole "Constructing asf index block" there is just this big "missing codec" in the middle of frame. (edit: just tried installing wmp11, still have same issue)
man, both wmv and mov are such massive pains, but wmv is not usually that bad.
Try this.
First, install wmp6cdcs from Microsoft. This package contains the following codecs:
Windows Media Video 9 VCM
Windows Media Audio
Windows Media Screen v7
Windows Media 9 Voice Directshow
Windows Media Video 8
MS MPEG v1, v3
ISO MPEG 4 v1, v1.1
http://www.microsoft.com/downloads/details.aspx?FamilyID=9be479f8-3b3f-491d-9284-2e1a8...displaylang=en
Make sure you have ffdshow installed and in Virtualdub, select video, compression and choose the ffdshow video codec. Under Configure, for WMV1/ 7 and WMV2/8 choose WMV9. -
tnx for the reply.
Windows Media Video 9 VCM fixed a lot of them... still cant edit some, but I suppose directshowsource can be used for those... -
I don't have any problems with 7,8 or 9 but I am having problems with the Windows Media Audio 9.1 Professional audio in WMV-HD.
I'm pretty sure I was able to decode these files in Virtualdub before I replaced my MB and CPU but can't seem to get them to decode now without Avisynth.
They play fine in Media Player Classic. -
Found a workaround for the Windows Media Audio 9.1 Professional audio in WMV-HD.
Use dBpoweramp Music Converter (it's free) to convert the 5.1 Windows Media Audio file to 5.1 wave file (open WMV in dBpoweramp Music Converter and select Wave > 6 '5.1 Suround' DVD).
Open WMV in Virtualdub 1.8.0 and select Audio > Audio from other file (select 5.1 wave that you created)> Full Processing Mode > Compression > AC3-ACM -
Actually, the current version of dbPowerAmp Music Converter is shareware. I think the last free version was somewhere around Release 10 or so.Originally Posted by DarrellSIf cameras add ten pounds, why would people want to eat them?
From my understanding, you have to buy a license to use certain parts of it but the converter itself is free.
The only time I get a nag screen is if I try to use the Fraunhofer 5.1 MP3 codec and it says component needs reference
powerpack and MP3 license: trial 29 days left
all media guide: 29 days access remaining
From my understanding, the free version will not convert to Lame MP3 after the trial period is up.
Vegas Problem! Can' edit .mov anymore!
By duderdude2 in forum EditingReplies: 2Last Post: 18th Jun 2010, 05:39 -
How can i quickly edit a wmv?
By Stemondo in forum EditingReplies: 2Last Post: 15th Apr 2009, 20:41 -
.flv videos will not play surround sound anymore
By finn.andersen in forum Video Streaming DownloadingReplies: 0Last Post: 17th May 2008, 07:55 -
Videos don't work anymore
By SINZAR in forum Software PlayingReplies: 5Last Post: 14th Mar 2008, 13:46 -
I can't see videos anymore!
By cece0808 in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2007, 19:46
