Created DVD with 3 episodes of same TV show. Episodes were 6-8 and created buttons called "Episode 6" etc.
Did this very carefully as this was my first project and I was using the free trial version. Created buttons as image buttons and put background in by taking snapshot from the TV show. Everything appeared to go well and end result was quite impressive (thanks to training video which was very, very clear).
Unfortunately on the final product the buttons have been assigned to the episodes in reverse order i.e. Ep6 with button 8, Ep7 button 7 and Ep8 with button 6. Not put off I was so impressed overall that I donated and installed full version and repeated the project. As you might imagine I was doubly careful this time but exactly the same thing happened 6+8, 7+7 and 8+6.
Any suggestions/solutions
This is the first report of such an error and as such I suspect it is a result of a problem in your work flow. After adding an asset to a VTS double check that assets properties by clicking on it. The asset should play in the preview window and it's properties should be displayed on the right hand pane. I think that you somehow have reversed your intended order in adding the assets. If you still have problems post your log file.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Posting your log should clear this up.
I am sure I am a twit but...DVD episodes to avi files
By cheerychops in forum Newbie / General discussionsReplies: 9Last Post: 5th Aug 2010, 10:39 -
TV Series, more episode length files than episodes on disc.
By Mick1988 in forum DVD RippingReplies: 2Last Post: 1st Jan 2010, 09:58 -
spumux menus and buttons alignment
By begemotv2718 in forum Authoring (DVD)Replies: 1Last Post: 3rd Aug 2008, 10:31 -
Easiest way to convert episodes from a dvd to single episode files?
By Pj10 in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2007, 22:42 -
Episodes from Several DVD's Onto One With Menus and Chapters
By Savutay in forum Authoring (DVD)Replies: 0Last Post: 12th Oct 2007, 16:41
