    Jan 2008
    Hey! I recently purchased a gamebridge: http://www.amazon.co.uk/2179900-Adaptec-GameBridge-AVC-1400/dp/B000DLBAFU and I'm having trouble recording in PAL60, I can get a picture (not like others) in Virtualdub, but the quality is screwed.
    I'm being told that the gamebridge wont work in PAL60 but I don't want to blow all my money on the "Dazzle Platinum".
    Heres what the pictures like: http://www.youtube.com/watch?v=xVZz38jen1c
    the quality was better before I uploaded it.
    Feb 2008
    you shouldnt have bought the gamebridge to be honest with you
    what options are set in your virtual dub?
    Aug 2006
    Good old PAL60! Well, no, it's not really, is it? It would be if it wasn't such a bugger to capture.
    I've been through hell and back trying to get my PC to capture PAL60, properly. And I must agree with the above post, you shouldn't have bought a Gamebridge. There are capture cards that are much better out there for the same price.
    I stumbled across some information that suggested this capture card, which is £25, can record PAL60:
    http://www.hauppauge.co.uk/pages/products/data_express.html
    I bought it last week, and I can confirm, it does capture PAL60 - perfectly! Although, you have to use Dscaler to do all the capturing. For some reason I couldn't get it to work in VirtualDub, which is annoying, but hey, can't have everything!
    I captured PAL60 in AVI (HuffYuv) format, in 640x480 resolution.
    Also, to allow you to play on the tv while recordin, and also bypass the lag, I use this SCART lead:
    http://www.amazon.co.uk/XBOX%C2%AE-360-to-SCART-CABLE/dp/B000V95LEA/ref=sr_1_7?ie=UTF8...2994560&sr=8-7
    You can play on the TV through the SCART, and record through the AV block with composites.
