Hi all,
Quick question authoring in DVD-Lab Studio. I want to be able to have special buttons or characters that I created in my graphics program to be visible only when selected, but so far I have not been able to make it work.
Currently, I have the selection buttons as invisible-selected. When I navigate to the buttons they show up as just a white outline of the the special charaters I created.
For example, lets say I have on my Menu:
PLAY ALL CHAPTERS EXTRAS
When the menu comes up PLAY ALL is immediately highlighted/selected with my special button, but the button is white instead of the way I created it. How can I fix this to perform like I want it to? Many thanks, all.
I do not know what program did you use, but some people use Photoshop and layers to create special buttons. I use Real Draw Pro for that which create the button in three layers ready for Lab.
I am sure if you post your question in Lab forum you will get better help since there are pro guys using this software.
http://www.mmbforums.com/ipb/index.php?showforum=24
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 06:03 -
Allowable Characters for a DVD title
By cal_tony in forum Authoring (DVD)Replies: 3Last Post: 23rd Aug 2009, 19:52 -
Scene Selection Menu in DVD-lab Pro2
By jole in forum Authoring (DVD)Replies: 5Last Post: 25th Feb 2009, 03:20 -
DVD-Lab Pro 2, making shaped buttons from parts of menu background?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2008, 19:06 -
"Play All" caused audio out of sync (DVD Lab Studio, Half-D1)
By iryu in forum Authoring (DVD)Replies: 5Last Post: 21st May 2008, 01:52
