    Dec 2001
    I have the .bins which I extracted with VCDgear. I took the mpgs and performed this: http://www.geocities.com/newestmoviesencode/dvdvcd
    Now, after I burn them and play them the audio is out of sync. I played the VCD in another DVD player (Apex 600a) it worked fine. The first CD I made was perfect. I ran the files through PVAStrumento and it told me: "Audio starts 76 ms early (->video delay on muxing)" So my question is how do I do this? How can I get it so the audio is in sync?
    Dec 2001
    What program can I use to correct the audio timing?
  3. I would think that you would need to delay the audio by 76ms but what program you use to do this I could not tell ya....maybe someone here who is better experienced at this can help ya out...good luck
    Dec 2001
    Has anyone used BBmpeg to try this?
