Hi
One of my clients bought several music dvd's. He made a selection of tracks and asked me to make a new compilation with those selected tracks on a new dvdr. What is the best way to do this.
thanks in advance
DVD Shrink. And if you want menus you can use it together with Tmpgenc DVD Author. See https://www.videohelp.com/guides/how-to-make-a-mixed-dvd-id502#502
You could also use DVD Decrypter to rip by chapters/tracks and then import in your dvd authoring tool. -
Apparently i can't select de chapters in dvdshrink, and burn them directly on a DVD.
So i ripped them in separate VOB-files with DVDdecrypter, each musicclip is a VOB-file. Now I'm having troubles with some VOB-files when I import them in encore. I get the following error.
could not import VTS_01_CHAPTER_02_1.VOB.
The file type is not supported.
I ripped 18 clips, and with 3 of them I get that error.
With the other 15 clips, i can make without any problem a new DVD. How does it come that 3 of them are not imported. I even tried to rip them separatly and import them again, and still the same problem.
thanks for some help -
Try extracting the mpg out of the non working VOBs with VOB2MPG. No idea as to why some work and some don't, but that may do as a workaround. Also, instead of getting the complete VOB from DVDDecrypter, you could set it to split it out into elementary streams, which may work better for your authoring app.
/Mats
Magix Music Maker - function to split vocal tracks?
By Artas1984 in forum AudioReplies: 4Last Post: 11th Sep 2011, 18:52 -
Is there any real value to "5 free music tracks from MyMusic for EDIUS
By TBoneit in forum Off topicReplies: 1Last Post: 22nd Jul 2009, 10:13 -
music DVD with cover display and albums/tracks menus?
By majordoc in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 03:20 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 12:56 -
Rip individual tracks from music DVD to iPod - How?
By Blowndakrt in forum Newbie / General discussionsReplies: 8Last Post: 17th Mar 2008, 03:35
