I simply cannot find a video converter that will convert flv videos to avis without a problem and it could be attributed to problems with my computer, but I have used online converters like vixy.net and the same problems have occured.
The first FLV converter I used was the Batch FLV Converter and it used to work perfectly. It didn't convert to avis with sound oddly, but I could resynch the video and audio tracks in movie maker. Now for some reason when I convert flvs now, only a certain percentage of the video will be converted, such as 6:11 or even less, and this will remain the same for all videos longer than that length that I convert during that particular session. The only tell tale sign that something wasn't quite right with the program was the incredibly long time it took to convert one single video.
The current one I have tried using is Total Video Converter, and for the first time I was able to convert flv videos to avi using the mpeg4 codec successfully and I could even import them into movie maker without problems too. However, this program is now playing up on me too. It converts incredibly large files that come with the audio track in tact, but it freezes at either the first frame or at any point i click on the clip. If someone could provide some useful advice on this matter it would be most appreciated.
Results 1 to 20 of 20
Try convert to some other video codec in total video converter. I don't know what you can select but try different and see if it works better. You can also convert to wmv and you should be able to import in wmm.
Or try convert the FLV with SUPER or WinFF. -
I use..... WinAVIVideoConverter...... to convert from FLV to DVD and works OK.
You also have the option to convert to AVI as well.
Also does batch conversions
I did 12 in one go....
Hope this helps you. -
Hi, newbie here with a similar problem. I have been trying to convert a large flv file to
avi for weeks. I have tried every program out there, I'm sure. It converts but when it
does the sync is off. For instance, I used ConvertXtoDVD and the picture is near perfect
but the audio isn't in sync with the video.
Here are the specs of the file:
Audio: MPEG2 Layer 3 (CBR 32 kbps, 1 cn, 22050HZ, 9.37 mbyte
Video: FOURCC: FLV1 (1.28 mbps, 301 mb. 00:32:52.733
Is there anyone who can tell me how to convert this without losing video
quality and keeping audio in sync? I would be eternally grateful!! My sanity
is at stake here. There must be a way to do this. -
Have you tried FLV Extract? That should demux an AVI video stream from the FLV, and the MP3 audio stream. All you'll need to do is mux the AVI and the MP3 together.
(Note that the AVI will still be compressed using the FLV1 codec, so you'll need to have a codec capable of decoding FLV1 streams installed, like ffdshow. Other than that, it should work fine.)If cameras add ten pounds, why would people want to eat them? -
You might also give this a try : https://forum.videohelp.com/topic343157.html
AlltoAVI also seems to work fine, at least for me.
However :
If nothing works on a single file, then the file is at fault and should be tossed.
If nothing works on multiple files the you have serious system problems and it may be time for a format and rebuild.Read my blog here.
Ai Haibara: Thanks. I tried FLV Extract but when I use AVI Mux
it's still out of sync.
theewizard: Thanks also. I am downloading SUPER now but honestly
I think there must be something wrong with my system because
no file I try converts properly. -
No. I leave it as it is. It's strange because I adjusted the mp3 length inOriginally Posted by guns1inger
sound forge to match the length of the video and I then I tried to put
them together in avi mux and that didn't work either. It's still the same.
Does it make any sense what I did with sound forge? I have Sony Vegas
too. Shouldn't I be able to get the avi and audio in sync using Vegas
and Sound Forge? -
This is what I get now. The picture is all distorted:
http://pic20.picturetrail.com/VOL1600/1801090/3469051/302066253.jpg -
That's odd. The FLV Extract > remux process normally shouldn't introduce any sync problems, as you're just extracting the streams of the original file and then gluing them back together, again.Originally Posted by lyekka790
No conversion involved. I'd wonder if AVI-Mux was doing something to cause the sync problem, but it shouldn't.
If you still have the files you extracted using FLV Extract, do the running times of the AVI and MP3 match?
Do the converted AVI files play properly if you use a player that doesn't depend on the codecs or DirectShow filters installed on the system, like VLC or mplayer?If cameras add ten pounds, why would people want to eat them? -
No, they are different. The video runtime is 32:52 mins. and the audio is 40:56 mins.If you still have the files you extracted using FLV Extract, do the running times of the AVI and MP3 match?
I played the converted avi file in VLC and it was still out of sync. But when I play it, say, on
NERO SHOWTIME, the picture is distorted (see link below) but it's in sync. Very strange.
are these files FLV or swf
for swf files I have benn using a prgram called swf to video
from bytescout software
you can get a fully functioning 45 day trial DL from their website
also most FLV off youtube is 25fps and 320*240
when converting to avi in super, I keep the 320x240 RES and set 25 FPS and use mpeg4 codec, mp4 output ext, and set the video bitrate at between 240-576
all this helps keep the audio & video in sync
when super little window pops up with (4) choices for the codec, i choose mp4v
I don't alter the size of the video RES until the next operation
most of my youtube stuff ends up on portable devices like cellphones ( mine ) or ipods ( friends ) so i'm not leaving it in avi or converting to DVD -
Thanks. I tried it and it's good but it's still out of sync.Originally Posted by sardonic
It's an FLV file. But now I managed to get the convertedOriginally Posted by theewizard
avi in sync but it sounds like chipmunks! When I change
the pitch, the file is bigger and goes out of sync again.
So now I have the choice between an out of sync file or
one that's in sync but the voices sound like chipmunks! -
Yes, you can check it out here:Originally Posted by theewizard
http://www.netsearchdirect.info/elizabeth.flv
I may have too many video programs- I cannot get my capture to work
By FLVidiot in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2010, 00:45 -
Programs won't reconize video file ?!
By Beastly Swagger in forum Video ConversionReplies: 1Last Post: 26th Jan 2009, 18:42 -
Do any of these editing programs work well?
By 392 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2009, 21:33 -
No capturing programs work on Vista (home premium 32-bit)...
By Rein Engel in forum Capturing and VCRReplies: 8Last Post: 28th Nov 2008, 19:42 -
Will my video programs, codecs, etc, still work with Windows X64?
By HartsVideo in forum Software PlayingReplies: 15Last Post: 5th Sep 2008, 14:09
