With the new HD capture devices right around the corner (like this one), I'm really excited about the possibility of editing HD footage.
After capturing an H.264 video, I'd like to be able to edit the clip and encode it as a WMV file for streaming online, similar to what you see here:
http://xboxmovies.teamxbox.com/xbox-360-hires/6226/Gameplay-Footage-4-HD/
My question is, how the heck do sites like this get this level of video quality with such small file sizes in the WMV format?
I can get a similar filesize with comparable quality if I'm converting the file to an Xvid AVI, but whenever I try to create a WMV file, the filesize becomes much larger than the one linked to above.
Sony Vegas is my main tool for editing and rendering video, but I can learn a different tool if I need to. Any advice would be appreciated.
Can't you set a custom bitrate in Vegas? Set the bitrate to 5MBit and it will be same size. Or does it looks like crap then?
And you can try convert to wmv9 or wmv vc1 using windows media encoder or wmnicenc.
And I wouldn't say that 5Mbit is that low size or well for HD is it not that much though.
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 09:21 -
How To Produce High Quality WMV from AVI / DVD Files?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 24th Jan 2010, 22:13 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
Best way to convert a low quality WMV to DVD?
By Bix in forum RestorationReplies: 2Last Post: 20th Sep 2007, 20:08
