In HDV world, is there any benefit of PAL over NTSC?
Also, what are the actual resolutions of this camera (in line out, or DV out) in the various modes (1080i, 24p, 24F)?
Of all the camera modes, which will give best Image Quality for almost stationary nature scenes?
Results 1 to 10 of 10
Originally Posted by W_Eagle
The NTSC model works in standard NTSC DV modes or HDV 1080i/p (not 720p)
DV standard 4:3 720x480i 29.97 fps
DV wide 16:9 720x480i 29.97 fps
HDV 16:9 1440x1080i 29.97 fps
HDV 16:9 1440x1080p 23.976 fps (24f telecined to 29.97 fps)
As for nature scenes, the HDV 24f mode is good with a heavy tripod. Image "quality" is about the same for interlace or progressive modes. you would choose one or the other based on your distribution needs. 24F mode is easier if the goal is to release in both PAL and NTSC but you need a good editor that supports 24p post production. The work flow can get quite complicated.
To understand the basics of 24p/24pa/24f look at this
http://www.adamwilt.com/24p/Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks.
Indeed, I'm in a PAL country, however, all TV sets and projectors here are dual system. I know that in standard TV resolutions (720x576 / 720x480) PAL has an advantage in IQ, so my question is whether that advantage is still maintained in HD?
There will be few channels, distributed over LAN, parts also over the Internet infrastructure. Therefore, the transmission will have to be compressed to MPEG4 on the fly, by either software or hardware. However, no editing will be done. It will be a live "broadcast" from few spots.
Each camera will be mounted on a tripod, though not a very heavy one, unless a heavy one will be needed. Also, there will be a servo mechanism panning very very slowly each camera.
Under those circumstance, which mode is best, 1080i, 24p or 24F?
Is there a software to effectively compress and decompress HDV on the fly to MPEG4? If no, is there such hardware?
Whish MPEG4 codec will give the best compression, without any artifacts, to an almost stationary scene (stationary with an extremely slow panning)? What will be the bitrate? -
You have a complex project. An HDV camcorder outputs "live" as 25 Mb/s MPeg2 over IEEE-1394 or uncompressed over HDMI. Both have limited cable length so a hardware encoder would be required at the camera position.
You might want to consider a high definition security type camera with pan/tilt and internal streaming network output. Some use wireless Ethernet.
This is just one example .. Sony BRC-H700 (3x 1/3" CCD w/12x optical zoom and autofocus)
http://www.communitech.com.au/proshop/show_product_details.php?catid=&products_id=500Recommends: Kiva.org - Loans that change lives.
Thanks.
Indeed, I have a complex project.
Since the cameras will be mounted outdoors, unattended and since an automated servo mechanism for panning is required, the Sony BRC-H700, or a similar one, will be the proper solution. It does cost more than Canon HV20, however, this is the equipment that suits the task.
What hardware encoders may suit the job? -
Thanks.
However, right now I have to present costs for a project to be implemented immediately. -
Canon HV20 transfer to DVD
By arobertson1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 8th Aug 2008, 06:35 -
Canon HV20/HV30
By Tyler2000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 31st May 2008, 13:43 -
Canon HF10 NTSC or PAL
By Jone.T in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 29th May 2008, 11:57 -
CANON HV20
By onionfish in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2008, 16:28 -
Capturing with the Canon HV20
By seven_deuce offsuit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 33Last Post: 2nd Nov 2007, 22:48
