Reads and writes DVD's perfectly, writes CD's to virgin CD-R media, or add-on. However, will only read 50% of my archival photo cd's, (CD-R) all prepared on the same older Pioneer 112. I need to extract files from these and don't want to be running back to the older computer in another room.
"Won't Read" means the drive acts as thought there is nothing in it, no matter how I attempt to open the files, they are just not displayed.
Any ideas?? BTW, this computer and burner are brand-new - 1 month.
Thanks,
Abueloloco
Results 1 to 11 of 11
There was a huge recall on PIONEER 112 & 212 drives with problems regarding CD-R. Your 112 drive could have that defect. Do a google search on recall on PIONEER 112 drives. I had a defect with the 212 drive and all PIONEER did was repair it. The defect is reading/writing of CD-R discs. I have the link for the PIONEER form but I'm at work right now so do a search on google.
Another thing is what brand of CD-R discs are you using? Just curious. -
Budz
Thanks for the info. It might be cheaper for me to add a CD writer than return for repair, but I'll check the pioneer site.
Hard to tell on brand as some disks are labelled, but there are some TDK, and some Staples house brand. -
Budz:
Was that the Pioneer Firmware update dated Dec 7 that you did, (DVR-212D_FW124EU2.EXE) or did you return it for repair?
Regm -
I don't think I had the firmware 1.24 when I sent the drive back to PIONEER. I'll have to check that computer and let you know.
Unfortunately the brands of CD-R like TDK & STAPLES isn't considered good quality cd-r media. -
I checked my 212 and it does have the firmware 1.24. I'm assuming when PIONEER repaired my drive it flashed it to the latest firmware.
If you can burn CD-R with it then you have a fully working drive and just that problematic discs were burned badly or crapped out over the time.
*** Now that you have read me, do some other things. *** -
Chef:
Thanks for that. I can still read them on the drive they were burnt on, so it is probably one of those two problems, so...I'll just take the data off on computer 2 and take it to co uter 1 and re-burn on the newer drive.
thanks,
Reg
DVR-112D Won't burn or read any DVD
By Genwifa in forum DVD & Blu-ray WritersReplies: 3Last Post: 3rd Oct 2008, 02:36 -
Pioneer DVR-531 TV Guide won't come up
By MCnDaHouse in forum DVD & Blu-ray RecordersReplies: 11Last Post: 4th Aug 2008, 21:17 -
Pioneer DVR-212D Abit NF7-S ?
By JockMcJock in forum DVD & Blu-ray WritersReplies: 5Last Post: 14th Jul 2008, 03:23 -
Pioneer DVR-112D connects but won't burn
By JessW in forum DVD & Blu-ray WritersReplies: 19Last Post: 1st Jul 2008, 00:41 -
pioneer 510H will burn but won't read unfinalized discs
By nixie in forum DVD & Blu-ray RecordersReplies: 10Last Post: 6th Jun 2007, 19:25
