I am using WinAVI 8.0 and I am converting AVI to DVD. Before the converting the sound is perfect but when it is done I can't hear anything! This is so frustrating! What am I doing wrong?
Results 1 to 9 of 9
You're using the worst tool ever sold for this task. Try free FAVC or commercial Convertx2dvd.What am I doing wrong?
Or even better: Get a DVD player that also plays DivX/XviD AVI, and don't convert at all. You could have picked one up for the same amount you paid for WinAVI.
/Mats -
Yes it is. Your only question was
and that was answered. Using the wrong tool, quite simply. (And perhaps lacking an audio codec)What am I doing wrong?
/Mats -
What are you playing the DVD back on? If it's a computer and the audio is AC3, you may not have the proper codec installed. If it's on a set top player, then I would try a different converter program.
You should also check the file before and after conversion with Gspot 2.70 and see what audio format it is using and if there really is audio in the DVD file. Just because you can't hear it doesn't mean it's not there. Other common problems with Xvid files are MP3 VBR audio, which many programs don't handle well, or sometimes even AC3.
And welcome to our forums.
In what way didn't it work? And believe me: WinAVI is the utterest of all utter crap, not worth spending one single byte of not-so-precious HDD space on, let alone trying to figure out why it doesn't work as advertized.Originally Posted by breezestar
/Mats -
I installed FAVC and AviSynth and the required codecs but it didn't work anyway, getting tired of trying to fix a good converting program! :S I tried to download .net Framework 2.0 (I have 1.1), and I ca'nt download it. It says that my current version can' take the 2.0 version (or something like that). Drives me crazy...
Ripping, converting audio and then authoring the DVD
By vishwanath in forum Authoring (DVD)Replies: 10Last Post: 13th Jun 2011, 22:58 -
ripping and converting
By bigmacsexgod in forum DVD RippingReplies: 1Last Post: 26th Dec 2009, 11:40 -
no sound ripping dvd to avi/mkv/mp4
By runLoganrun in forum DVD RippingReplies: 1Last Post: 19th Dec 2008, 13:52 -
Ripping And Converting
By Lennoxtown in forum Video ConversionReplies: 4Last Post: 17th May 2008, 04:39 -
help with ripping the individual episodes from the dvd and converting them
By dvdrburner in forum DVD RippingReplies: 1Last Post: 22nd Aug 2007, 07:14
But my questions aren' t exactly answered...
