I have just installed the software and all components. I THINK i installed the flv component through terminal. Not a pro at terminal...
I tried converting a mov file to flv
it exported but the flv file was only zero KB
so, i assume it didnt work.
any help? any way to know if it actually installed properly?
thanks yall
scott
Results 1 to 14 of 14
here is what it said:
Encoding started on Tue Jan 29 17:26:23 EST 2008
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/*scott/*KidKoala/video/mexico_vids/small/kidkoala_dub_mexico.mov':
Duration: 00:04:15.0, start: 0.000000, bitrate: 5400 kb/s
Stream #0.0(eng): Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Stream #0.1(eng), 29.97 fps(r): Video: h261, yuv420p, 352x264
Codec type mismatch for mapping #0.0 -> #0.0
ok. so i did this. Now it did export and it became 8.2 mb in size. i opened in flash player but nothing happened. here is the info
Wed Jan 30 11:23:22 EST 2008
Output #0, flv, to '/*scott/*KidKoala/video/mexico_vids/small/kidkoala_dub_mexico.mov.ff.flv':
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 352x264, q=2-15, 200 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
[h261 @ 0x54340c]warning: first frame is no keyframe
bench: utime=25.240s
video:1835kB audio:1744kB global headers:0kB muxing overhead 135.029176%
/bin/sh: /Applications/ffmpegX.app//Contents/Resources/flvtool2: /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/bin/ruby: bad interpreter: No such file or directory
[s:7d02011bc3]Apparently, the installation of FLVtool2 didn't go well.Originally Posted by sadr
Try installing that again.[/s:7d02011bc3]
I was wrong, see two posts down.
hi...
i have the same problem...
i reinstalled the flvtool2 again and again...
but the created flv file is corrupted and bad...
here is the info file...
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Fri Feb 1 10:56:04 CET 2008
Users/photo_mac/Movies/Final-Cut-Projects/Play-the-game/ptg.mov':
Duration: 00:03:38.4, start: 0.000000, bitrate: 33492 kb/s
Stream #0.1(eng), 25.00 fps(r): Video: h264, yuv420p, 720x576
Output #0, flv, to '/Users/photo_mac/Movies/Final-Cut-Projects/Play-the-game/ptg.mov.ff.mp4.flv':
Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 432x240, q=2-9, 700 kb/s
Stream mapping:
bench: utime=99.826s
video:9380kB audio:1493kB global headers:0kB muxing overhead 65.477275%
where is the problem???
i also find some other bugs...
please help......
best regards from germany...
Originally Posted by sadrIt seems the script inside /Applications/ffmpegX.app//Contents/Resources/flvtool2Originally Posted by fap
points to
while on my system (10.4.11), and maybe yours as well, it should point to
/usr/bin/ruby
because that's where ruby resides on my system.
You can edit that in any text editor. (I did it with BBEdit.) The "bad interpreter: No such file or directory"-error no longer appears in the log. This fixes the metadata being correctly added to the .flv file.
With the wrong path in the script, you should get a valid .flv file without the metadata, just like the previous version of ffmpegX.
It won't fix bad or corrupted .flv files.
Flash Player plays .swf files, not .flv files, afaik.Originally Posted by sadr
.flv files play in VLC, mplayer or QuickTime Player with Perian.
To embed .flv files in webpages, playable with the Flash plugin,
you should install an .swf media player that links to the .flv file.
I've had good results with JW FLV Media Player.
Hello,Originally Posted by Case
how can I access /Applications/ffmpegX.app//Contents/Resources/flvtool2 ?
In applications I only see ffmpegX.app and this starts the application.
Normally I am working with windows, but a friend has a new mac book pro.
Please help me, thank you.
Now I changed the destination of script, but this "LoadError" comes.. do yo have a solution for that?
I hope you will not get impatient with me..
Thx for your help!
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/RSPB/Desktop/Michael Picard Konzert SiebenGiebelHof Drenkow 02-08.m4v':
Duration: 00:12:26.9, start: 0.000000, bitrate: 1602 kb/s
Stream #0.0(eng), 25.00 fps(r): Video: h264, yuv420p, 640x480
Stream #0.1(eng): Audio: aac, 44100 Hz, stereo
Output #0, flv, to '/Users/RSPB/Desktop/Michael Picard Konzert SiebenGiebelHof Drenkow 02-08.m4v.ff.flv':
Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 640x480, q=2-15, 200 kb/s
Sat Apr 5 13:59:25 CEST 2008
, stereo, 56 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
video:17884kB audio:5048kB global headers:0kB muxing overhead 2.536927%
bench: utime=79.384s
/Applications/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/flvtool2:2:in `require': no such file to load -- flvtool2 (LoadError)
from /Applications/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/flvtool2:2
Did you install the FLVtool2 (a separate download) correctly, as described in the 0.0.9y announcement and on the ffmpegX website?Originally Posted by maltePORN
It should be installed to /usr/bin/ (where many other command line tools reside, including 'ruby'). This is a totally different file from the one inside ffmpegX.
Either your file isn't there, or does not have the proper attributes to make it a command line executable. You need to do the four Terminal commands exactly right.
Converting VHS tapes to FLV files using Avanti
By ABBrittain in forum Newbie / General discussionsReplies: 4Last Post: 27th Jun 2011, 03:42 -
Converting FLV Files to DVD Playable Standalone
By Bonie81 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2010, 10:55 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
Converting .flv files
By gino_76ph in forum Video ConversionReplies: 8Last Post: 28th Mar 2008, 21:06 -
Converting FLV to 3GP --> FLV Unrecognized?
By SnakeGirl in forum ffmpegX general discussionReplies: 1Last Post: 21st Jan 2008, 22:33
