Quick question.
We use Adobe Premier Pro for editing. I bought the Surcode Dolby Digital plug in for 300$ that does 5.1 surround. We decided NOT to do 5.1 surround sound but when we export in Premier Pro, we pick the export setting with 5.1 surround.
My question is, will it take my wifes 2 track sterio file and FORCE it so be 5.1 surround in Premier when we export even though the source is just 2 tracks?
If you tell it to encode the audio as 5.1 AC3 it will, so you should make sure you set an appropriate bitrate. However encoding stereo audio as 5.1 without actually spending time creating a surround mix means you will just get the audio sitting in the middle of the field, not dynamically bouncing around. You would be better of just encoding to 2.0 and letting Dolby PL II do the work at playback.
Read my blog here.
Adobe Premiere Elements 7- How do I make it fullscreen?
By robvs in forum EditingReplies: 3Last Post: 20th Jan 2014, 05:13 -
Adobe Premiere Pro How do I make the video Bigger?
By Devilsadvocate in forum EditingReplies: 5Last Post: 25th Mar 2012, 15:44 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
DVD - How do I make all files play automatically?
By gina_here in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 14:25 -
Adobe Premiere question about how make Titles appear to be typed
By slam87 in forum EditingReplies: 2Last Post: 9th May 2007, 15:10
