my specs windows xp 7 and cgange of ram...ge force 6600 le TDK DVDR840G firmware ver 1.12
read write speed 40x buffer size 2 mb...i rememberseeing something saying something about policies excuse spelling are messed up can anyone help i can't even get windows xp disk to start..im looking at the light it does its normal thing then it seems like its going to turn green and start than at that point it turns blinking yellow like its stuck evvery single disk i have...i dont know what to do anyone help? THX
Results 1 to 10 of 10
Did you try reading in 'Safe Mode'? You should be able to boot to that at startup. Usually the F6 or F8 key or your BIOS screen may tell you.
But you may have damaged the registry. If so, I would consider a XP reinstall or at least a repair reinstall. You usually need to change your BIOS to boot from CD.
And welcome to our forums. -
yes i just tried in safe mode nothing even tried autoplay reg fix nothing still yellow constant light than continuing blinking orange light?
to re-install the drive driver, go to my computer/properties/hardware/device manager/click on dvd-cd drives/right click on the drive and uninstall. reboot and the computer will find the drive as new hardware and install it. if it still won't work, either it's toast or windows is.
Spelling is no big deal. But at least an attempt at typing in complete sentences makes it easier to read and understand what you are trying to say.
Does the PC boot into Windows?
And this post should be in the computer or DVD writers forum.Google is your Friend -
forgive my english is not so good sometimes it is knowing where someone is coming from...Yes windows does come on everything starts and restarts normally..and THX 4 ur reply
OK.
So Windows boots up normally, but when it is running your DVDROM won't read any discs? You should try a CD and a DVD. You can also try the suggestion above by aedipuss, it will often correct some issues.Google is your Friend -
With so many disc problems, maybe your DVD drive went into PIO mode instead of the normal DMA mode... explanation and fix here... worth checking anyway?
wabjxo
That’s a very good link, that explains the issue very well.
I don’t use XP for much as I use mostly 98se
I had forgotten that XP would do this. -
i did all suggestions made sure dma is on and uninstalled re-installed in device manager still the same thing THX all for ur responses.
Samsung tv wont read subtitles
By BigAl77 in forum SubtitleReplies: 15Last Post: 9th Sep 2016, 12:59 -
Google redirect virus, I can not remove it...
By Denvers Dawgs in forum ComputerReplies: 12Last Post: 27th Aug 2014, 06:19 -
DVD+RW Wont Be Read
By WoH-George in forum DVD & Blu-ray RecordersReplies: 8Last Post: 26th Jun 2011, 13:28 -
How do I remove/repair AVI video file virus?
By paulywalnuts in forum Newbie / General discussionsReplies: 6Last Post: 7th Feb 2011, 20:40 -
Disk wont read
By rheming3 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Dec 2008, 01:03
