My sony dvd player is regionfree. My dvd-movies ( they are original, I bought them at Play.com ) are region 1. But my ASA 28" television ( it's made in about 1992 ) doesn't have NTSC. However, the dvd's will play, I can watch rhem and I can hear the voices and subtitles in the movie will show. But only problem is that I can't see them in colour. I can watch them black&white. But do I have to buy a new television if I want to see those dvd's in colour?? Or what? ( all my region 1 dvd's are colour movies ).
Start by checking your DVD player settings. You can probably force it to output NTSC material as either PAL or PAL60. Your TV should handle either and give you colour. The compromise may be a loss of smoothness during pans and zooms. Failing that, unless you really want to get a new TV, you might consider changing your player to one that will output NTSC as PAL. I certainly don't see it as warranting a format conversion except as a last resort.
Read my blog here.
Hi. Thanks. "Start by checking your DVD player settings. You can probably force it to output NTSC material as either PAL or PAL60." how I do that?
Player is sony dvp-ns330. I bought it 3-4 years ago. I saw what button "display" said, but nothing like that... Is it "picture mode" button? Or what should I press?, I just didn't find like that. -
there isn't a mention of ntsc in manual. But I tried to see with remote control;
setup, custom,
-screen setup?
- custom setup?
- audio setup? ( not this one )
Manual is made 2003. -
Hi sonydvd,
The Sony dvp-ns330 can according to the manual output RGB, so you should be able to watch the movies in colour when using a SCART cable that supports RGB. The player can be set to output RGB on the SCART in the "SCREEN SETUP/LINE".
vcd4ever.
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 05:35 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 22:10 -
Portable DVD player. Region free. Pal/NTSC
By jtrinc in forum Portable VideoReplies: 2Last Post: 16th Aug 2010, 10:28 -
Can AutoGK convert PAL Region 3 dvd to NTSC .avi?
By bloomcounty in forum Video ConversionReplies: 14Last Post: 20th Nov 2008, 20:31 -
Converting PAL Region 2 to NTSC region 1
By bevluvsrats in forum Video ConversionReplies: 10Last Post: 21st May 2008, 10:15
