Just a few minutes ago, when I was watching TV, the screen suddenly turned off.
The cable box had words that said "Proc," and "boot," and "-nu-," "Er.50", "Fr.LA".
Then it started showing all these numbers like "r402" or "r37h" or "r24k" and continues in that orderuntil it reaches "r000" and starts the cycle all over again.
What do you suppose happened, and is there a way to fix it?
	Sounds like the box died. Call your provider and have it replaced. Google is your Friend
	Never mind, it was only like this for three hours, then it was working like normal again.
 Though, I'm still wwatching for if it will ever happen again.
  Does a DVD recorder need digital tuner to receive content from a cable box?By True Colors in forum DVD & Blu-ray RecordersReplies: 23Last Post: 18th Apr 2014, 10:17
  Connect LCD monitor to Digital HD Cable box?By rogerconnery in forum DVB / IPTVReplies: 84Last Post: 18th Jan 2012, 07:04
  Direct Cable Or Digital Converter Box, quality questionBy allthumbs in forum Capturing and VCRReplies: 20Last Post: 3rd May 2009, 21:55
  Testing with a digital converter box on a cable system.By 389poncho in forum DVB / IPTVReplies: 36Last Post: 6th Jan 2009, 20:18
  Digital Cable Box, DVD Recorder, Television Hook Up Problems!By robdawg70 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 30th Jul 2007, 15:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
