Ok.. so I just bought Pinnacle 11 and I am finally going to try my hand at finally moving all my tapes over to DVD.
I got the DV capture going... and I was fiddling around with creating a short clip out to a file (mpeg 2)
So here is my question / issue... when I view the file (the mpeg 2 file), it seems ok.. but I notice that it seems to have kind of some horizontal shifting going on at times. Is that just a function of the computer rendering the video? Or is there some setting I have not adjusted... etc??
The footage in question was recorded in 1995 using a Canon ES70 8mm Camcorder...
http://www.canon.com/camera-museum/camera/8mmvc/data/1993-1995/1994_es70.html?lang=us&...=1993-1995&p=2
I used DV capture on this footage (although the same thing happened using an analog capture on the same footage)... would that matter?
Thanks in advance.
Ok... so I figured out the "issue" myself.
The issue was that I was re-sizing the video when I was viewing it. When I watch the video at its original dimensions, it views just fine (without the horizontal shifting).
Subtitle massive shifting
By zibizibi in forum SubtitleReplies: 5Last Post: 12th Jul 2011, 07:32 -
shifting audio
By jimhoofd in forum AudioReplies: 5Last Post: 15th Apr 2010, 18:56 -
Need help with video editing, shifting colors
By VideoDavid in forum Newbie / General discussionsReplies: 6Last Post: 9th Apr 2010, 14:30 -
Problems with brightness shifting
By Jerry1964 in forum EditingReplies: 5Last Post: 18th Oct 2008, 08:51 -
Shifting and Ghosting
By NightFire in forum RestorationReplies: 11Last Post: 28th Jul 2008, 19:29
