I have amplified the audio in a DivX file with Audition.
But it saved the file as a PCM. This will now not play in my DivX player
Can someone run me through changing the audio to an MP3 file.
Can't you export to mp3 in adobe audition? I guess it's under File > Export > Audio Mix Down and under file format or similar.
I though that MP3 was a native format for Audition (at least it is on my version).
The proceedure should be FILE > SAVE AS > .MP3.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by SLK001
Perhaps if I give more details.
I had a Divx file but the sound was too low.
I imported into Audition, raise the volume and saved the file.
But it saved the audio as a PCM file. So the file won't play on my standalone player.
Try as I may I can't get the bugger to save as an Mpeg.
Can someone run me through this please.
Thanks -
Another way of increasing the volume in your AVI
https://forum.videohelp.com/topic314909.html
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
Problem stretching AC3 audio with Adobe Audition 1.5
By Gwar in forum AudioReplies: 6Last Post: 21st Aug 2011, 07:15 -
How would I slow audio down 4% using Adobe Audition?
By Hittz in forum AudioReplies: 11Last Post: 2nd Jan 2011, 03:53 -
Audition puts audio out of synch
By blitzen in forum AudioReplies: 7Last Post: 7th May 2010, 16:52 -
Adobe Audition Mixdown- Slow audio
By tharps22 in forum AudioReplies: 0Last Post: 30th Nov 2009, 00:04
