The audio and video are out of sync before I even output my project? I add my video files, create my menu then I go to the Simulation screen to preview it and it is very out of sync. I though maybe it was just within tda so I created my video_ts folder but the resulting output is the same. Is there a way to somehow offset the audio so it starts sooner or later so I can try to sync them up?
Results 1 to 9 of 9
What is your source file(s)? container(avi,wmv,mp4,etc) and video and audio codec.
Avi container xvid codec. Not sure of the audio codec since i'm not at that pc.
For avi xvids I would use something else like dvd flick, favc, convertxtodvd. If you want nicer menus than those all-in-one converters you could import the DVD in TDA and recreate menus.
Thats actually what I do now but I figured if I could do everything in TDA it would save a step. I though maybe this was a common issue and maybe there was a quick fix since the sync issue is before the actual convert maybe it was a setting within tda? I'll just continue to use convertxtodvd to convert and then tda to author. Thanks
There should be an offset setting available in the Audio Filter section of the Clip Edit page. I think it's not called Offset; maybe 'Delay', or something like that.
Interesting. I'll ckeck that out tonight after work. In the meantime can anyone else confirm this, perhaps a screenshot of where the setting is? ThanksOriginally Posted by Semaphoric
I'd be guessing VBR MP3, and would fix that before encoding. Otherwise you may find it doing all sorts of odd things. There are plenty of posts on how to fix the audio before encoding. Either that, or use a tool that understands and deals with VBR MP3 audio correctly. Baldrick's list covers the main ones.
Read my blog here.
In the Clip Edit window, click on the musical note icon in the lower left corner, to bring up the Audio filters window.
There, select the Audio Gap tab, and activate Audio Gap Correction. The correction is in milliseconds.
Kick Ass To Ipod encode Audio Always Out Of Sync
By ZenMystic in forum Video ConversionReplies: 5Last Post: 15th Aug 2010, 21:15 -
Audio out of Sync on webserver encode using mencoder
By misterio in forum Video ConversionReplies: 2Last Post: 28th Nov 2008, 02:20 -
am trying to encode to xvid from dvd audio sync issue
By Onceler2 in forum DVD RippingReplies: 28Last Post: 3rd Sep 2008, 21:01 -
Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of Sync
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 14th Jul 2008, 01:25 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 09:20
