I have a Samsung HD960 dvd player that I bought last year. It has been a good player so far. In the last month I have noticed a problem with it and I have not been able to find any information about it and I was wondering if anyone here has had similar issues. I have noticed when I get ready to play a movie the disc tray is open and will not close unless I unplug the player, plug it back in, and then power it on. After this it works fine until the next day. When I look at it the next day the tray is stuck open again. Any ideas what is causing this?
Faulty/dirty tray sensor or just the tray controller circuit. If it isn't under warranty/maintainance agreement, then it is likely cheaper to replace than have it fixed.
Google is your Friend
Toshiba SD-3990 DVD Player Tray Will Not Open
By TufrThanu in forum DVD & Blu-ray PlayersReplies: 13Last Post: 29th May 2016, 02:04 -
Panasonic S97 tray will not open
By southland66 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Nov 2011, 02:24 -
Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
By daveshostack in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 12:41 -
Tray hard to open on LITE-ON LH-20A1H
By mn072065 in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Nov 2007, 09:05 -
liteon disc tray will not open
By northy44 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Sep 2007, 08:20
