Hello I hate to bother y'all with such a small thing, but I can't figure out how to do a "One Touch Recording" or "Segment Record" on the Toshiba RD-XS35.
That's where you usually press the Record button repeatedly to have the recording stop at 30min, 1hr, 90 min, 2 hrs etc.
I can't figure that simple thing out on the Toshiba and I need to use that feature. It says nothing about it in the manual that I can find.
Does anyone know? It must be able to it. It does everything else in great detail.
Also how do I enter channels manually? The TV Guide system only finds a few channels with my cable. I can tune them in if I input the channel number but I can't go up and down to bring them in. Better yet how do I get the TV Guide to find the other channels? It only found a few from Ch.3-24 and I left in on overnight for some days.
Thanks!
I don't have that recorder, but on my Toshiba recorders I use quick menu to set the stop time. Then if I want the recorder to shut down after recording stops, I use quick menu again and select auto power off.
Sounds like it is only scanning for TV (broadcast) channels and not cable channels.
Google is your Friend
How Much Should A Used Toshiba RD-XS35 Cost?
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 23Last Post: 4th Nov 2015, 23:54 -
Toshiba RD-XS35 features
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 26Last Post: 10th Oct 2008, 18:54 -
Toshiba RD-XS35 refurbs
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Mar 2008, 10:53 -
Looking for Toshiba RD-XS35 manual.
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 3Last Post: 25th Jan 2008, 09:28 -
Error Code 18 on Toshiba RD-XS35
By jrank001 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Dec 2007, 18:06
