Hi,
I tried AlltoAvi 4.53.0.93 version and I found all what I need from a converter.
I obviously got a little problem. I had a movie in ogg format and I converted it but I loose the 2 channels : It becomes Joint Stereo instead of Stereo.
Here are my infos read by mediainfo.
----------------------------------------Code:General #0 Complete name : Mymovie-ogg.avi File size : 352 Mio PlayTime : 42mn 26s Bit rate : 1158 Kbps Video #0 Codec : DivX 5 Codec/Famille : MPEG-4 Largeur : 640 pixels Hauteur : 352 pixels Format à l'écran : 16/9 Images par seconde : 25.000 Im/s Audio #0 Codec : Vorbis Codec settings/Floor : 1 PlayTime : 42mn 26s Channel(s) : 2 canaux Sampling rate : 48 KHz Language : french Audio #1 Codec : Vorbis Codec settings/Floor : 1 PlayTime : 42mn 26s Channel(s) : 2 canaux Sampling rate : 48 KHz Language : english
After the conversion
Do I forget something?Code:General #0 Complete name : Converted\cvt_ Mymovie-ogg.avi Format : AVI Format/Info : Audio Video Interleave Format/Family : RIFF File size : 359 MiB PlayTime : 42mn 26s Bit rate : 1183 Kbps Writing application : MEncoder 1.0rc1-3.4.2 Writing library : MPlayer Video #0 Codec : DivX 4 Codec/Family : MPEG-4 Codec/Info : Project Mayo DivX 4 Codec profile : Simple Profile/Level 1 Codec settings/Packe : No Codec settings/BVOP : No Codec settings/QPel : No Codec settings/GMC : 0 Codec settings/Matri : Default PlayTime : 42mn 26s Bit rate : 968 Kbps Width : 640 pixels Height : 352 pixels Display Aspect ratio : 16/9 Frame rate : 25.000 fps Resolution : 8 bits Chroma : 4:2:0 Interlacement : Progressive Audio #0 Codec : MPEG-1 Audio layer 3 Codec profile : Joint stereo PlayTime : 42mn 26s Bit rate : 192 Kbps Bit rate mode : CBR Channel(s) : 2 channels Sampling rate : 48 KHz Resolution : 16 bits Writing library : Lame 3.96.1
Joint stereo is no problem. Your problem is that you only got one of the audio tracks over to the AVI. Few converters support multi audio tracks sources.
/Mats -
Thank you for your answer,
What should it be your advice about the converter.
I have about 200 avi files with ogg audio encoding, I want to convert them by just choosing the french audio channel and keeping the stereo.
My dvd-player seems to have problems with ogg encoding. -
You could also use AviReComp, as that app seems to handle multi audio stream sources.
But:
Load the AVI in VirtualDubMod. Disable the audio you don't want in the stream list. Save out new version, using direct stream copy for both audio and video. You'll then have a single audio stream AVI that you can run thru alltoavi.
Or better yet - Ditch alltoavi:
Install the lame acm codec.
Do as above, but instead of using direct stream copy for both audio and video, just use direct stream for video, and change the audio codec for your remaining audio track to Lame MP3 and save. Done. This is a better way, as it in contrast to alltoavi/AviReComp does not reencode the video (losing video quality).
/Mats -
Thank you,
But it seems to be very long to proceed.
I agree that it also give a better quality.
Instead, I found avidemux. It's supposed to do what I need.
I used Video copy and Audio MP3 (lame), I'm not sure but it seems that the video looses quality by changing the bitrate to a little lower.
I just tried with one file. I will do for another to check. -
Avidemux does the same thing, yes. You can tell it to keep the video as is, as long as you don't specify a video codec. IIRC it defaults to what in VirtualDub vocabulary would translate to "Direct Stream Copy".
There are many ways to skin a cat!
/Mats
Preference for MP3 Joint Stereo Vs. Stereo ?
By davexnet in forum AudioReplies: 7Last Post: 27th Oct 2011, 11:49 -
Stereo V Joint stereo Again!
By Anonymous5394 in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2010, 10:12 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 22:24 -
Stereo VS Joint Stereo
By Anakin in forum AudioReplies: 4Last Post: 26th Mar 2009, 13:22 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 09:33
