My task is to transmit Full HD, or 1920 x 1080 50 Hz HD video transmission over LAN.
What is the bitrate and what line bandwidth do I need?
Uncompressed RGB? 1920 x 1080 x 3 x 50 ~= 311 MB/sec ~= 2.5 Gb/sec. There is also some overhead for transmission protocols.
Thanks. It will be MPEG2 compressed. What than is the bitrate / bandwidth?
Whatever the max bitrate of your MPEG2 data is plus some overhead. You're probably looking at ~30 Mb/sec. 100 Mb/sec ethernet should be fine if there's not a lot of other traffic.Originally Posted by W_Eagle
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 09:35 -
question about bandwidth usage
By mazinz in forum ComputerReplies: 8Last Post: 11th Nov 2010, 20:32 -
1080P Playback On My PC? And WD 1080p Player Need A Expert!
By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 12:43 -
HDV 1080p Im Looking for 1080p HDVs.
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 16th Nov 2008, 21:05 -
Does quoting someone else's post use bandwidth?
By moviebuff2 in forum ComputerReplies: 5Last Post: 15th Jan 2008, 20:16
