Try Lagarith. It's a free, fast, lossless codec. Files wil be rather large though -- about 20 to 30 GB/hr.
It's Save as AVI or frameserve. Frameserving is the passing of video frames from one program to another without creating an intermediate file. Not all MPEG encoders support this.
Results 31 to 42 of 42
got the lagarith and installed it and it showed up in virtualdub, created .AVI file of 18.5GB [inc audio] using null for the crop. Had to create a new partition coz of large file size!!Originally Posted by jagabo
[after processing/dubbing] snapshot was like this:
Now what can I do next, to get the .AVI into 16:9 MPEG-2 format???
thanx
I would have added the resize filter right after the cropping filter in VirtualDUb. Then your AVI file would be ready for conversion to MPEG with whatever encoder you have.
they say: 1 picture is worth a thousand words and your last caption is certainly true of that!!! I see what I should have done there!Originally Posted by jagabo
What I did was get TMPGEnc Express and it's looking like it will make a 16:9 in MPEG2 format for authoring in Tsunami author pro? Haven't got the result yet though?
your guidance is invaluable!! - many thanks!
..yet more invaluable advice for which I am most grateful. I have not tried the frameserver technique yet, but i will be doing that sometime soon!Originally Posted by guns1inger
thanks to everyone so far
TMPGEnc Plus accepts video frame served from VirtualDUb so I suspect Express does too.
You could be right about that too? (especially any newer versions).Originally Posted by jagabo
HERE IS THE RESULT, (image/snapshot taken direct from new DVD):="the_doc735"
on TV it looks like this
the TV is ON WIDE 16:9.
THE player is also on [shape] WIDE 16:9
The player is also on [system] NTSC
So there are no longer any black borders on the TV? Then everything is working properly.
...there are no longer any black borders on the TV!!!Originally Posted by jagabo
...many thanks to you (& everyone here)
Why doesn't the US mind releasing Fullscreen versions of Widescreen films?!
By takearushfan in forum Newbie / General discussionsReplies: 18Last Post: 16th Oct 2011, 23:38 -
1280x1024 Resolution doesn't fill screen?
By mccoady in forum ComputerReplies: 20Last Post: 17th Oct 2008, 19:56 -
Video height of 480 doesn't fill screen
By Grunberg in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 20:15 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37 -
picture doesn't fill TV screen - let me back up and start over.
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 22:48
