  1. I was authoring a DVD and I got this error
    ERR: Cannot jump to chapter 24 of title 1, only 23 exist
    ERR: in VTSM pgc 5, button 6
    Process aborted due to above error
    Error code #6
    There was an error in menu creation. One of the buttons jumps to a chapter that doesn't exist. Please review the log for more detailed information.
    If the chapter doesn't exist, then why does it let me select it in the menu editor? I know the chapter exists because I picked the chapter timings by opening the m2v in Virtualdub using Avisynth and a d2v file to correctly index it. I went into the chapter timing menu in DVDAuthorGUI and counted the chapters. There are 24 (once again, I would not be able to choose Title 1, Chapter 24 in the menu editor if it didn't exist.
  2. Most probably this error is due to the fact that there is no I-Frame after the timecode for your chapter 24. Either remove chapter 24 completely or move it at least 1 second away from the current position (towards the beginning of the movie) and retry. Another problem could be the issue with drop frame/non drop frame timecodes and/or pulldown flags (these complicate the mapping between frames and timecodes).
  3. Thanks, borax. You were right. It wasn't on an I-Frame. When I was figuring out the chaptering with Virtualdub (DVDAuthorGUI's preview decoder that gets the pulldown timings right takes too long to load the video), I first opened it as a directshowsource m2v and got a running time half the length it was supposed to be (probably because of the pulldown flag) so I opened it in DGIndex and generated a d2v and opened it as an mpeg2source with another Avisynth script file but that only gives you the K-frames (what virtualdub calls avi keyframes) and fortunately, that was the only chapter mark that was not on an I-frame. I opened the m2v file directly with virtualdub (which takes a lot longer to load up an m2v file) and picked a nearby I-frame for the chapter mark. I then ran the project again with success.
