Please, somebody help me! When i rip a dvd, using dvd decrypter or dvdfab HD decrypter, then i demuxe the files into AC3 and M2V to import via DVD Maestro (to author the dvd, cause the original has no subtitles), when i'm importing the files, the M2V video files stops in 89% and this message pops up on maestro:
Temporal References in GOP#9733(Zer-Based)are out of sequence(0xc10b000a)
Then, another:
Temporal References in a GOP are out of sequence. (0xc1070034).
The AC3 sound is corrupted as well (and crashes/stops in the middle of the importing process by Maestro), but i manage to fix it, using a couple of programs (Besweet and ffmpeggui);
I've already tried using ReStream_v090 to try to fix this M2V video file, but, it's always the same, it crashes in 89%, when i'm importing the file on Maestro. I'm starting to go crazy, please somebody help, i don't know what else i can do... the dvd itself (the one i ripped) plays fine, from the beggining to the very end... why this is happening?!
Decrypter can rip the dvd, but this "thing" shows up on the log:
I 19:58:32 File Splitting: None
I 19:58:32 Detect Mastering Errors: No
I 19:58:32 Stream Processing: Yes
I 19:58:32 Remove Macrovision Protection: Yes
I 19:58:33 Decryption Key: N/A
I 19:58:33 Extracting Sectors...
W 20:17:46 Skipping Sector 2014096 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014097 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014098 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014099 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014100 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014101 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014102 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014103 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014104 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014105 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014106 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014107 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014108 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014109 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014110 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014111 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014112 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014113 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014114 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014115 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014116 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014117 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014118 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014119 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014120 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014121 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014122 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014123 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014124 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014125 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014126 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014127 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014128 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014129 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014130 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014131 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014132 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014133 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014134 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014135 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014136 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014137 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014138 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014139 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014140 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014141 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014142 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014143 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014144 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014145 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014146 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014147 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014148 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014149 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014150 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014151 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014152 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014153 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014154 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014155 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014156 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014157 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014158 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014159 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014160 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014161 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014162 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014163 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014164 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014165 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014166 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014167 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014168 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014169 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014170 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014171 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014172 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014173 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014174 - Pack Header Not Found (0x00000000)
W 20:17:46 Skipping Sector 2014175 - Pack Header Not Found (0x00000000)
I 20:19:27 Operation Successfully Completed! - Duration: 00:20:54
I 20:19:27 Average Read Rate: 3.578 KB/s (2.6x) - Maximum Read Rate: 10.442 KB/s (7.5x)
When i rip using Fab HD Decrypter, it does not show a single thing, it only says that the rip was successful. I must fix this M2V file, in order to author the dvd for a friend! Please, somebody help me!!! Thank you so much!!!
				Results 1 to 1 of 1
  temporal degrainBy unclescoob in forum RestorationReplies: 10Last Post: 3rd Mar 2012, 23:53
  Mainboard cap replacement service referencesBy ranchhand in forum ComputerReplies: 6Last Post: 14th Jan 2012, 13:31
  Dye-based vs metal-based: which will last longer?By RedZone in forum Authoring (Blu-ray)Replies: 11Last Post: 11th May 2010, 22:30
  Book or web references on computer programming for DVDs?By newbee51 in forum ProgrammingReplies: 2Last Post: 30th May 2007, 20:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
