Hi,
I'm trying to convert VOX to mpeg2 - I've tried ffmpegx but I get problems with progress.app (where is progress.app) and then YUV convertor crashing (both issues are in the ffmpegx forum but no resolution seems to be available). Is there another application anyone can recommend?
Thanks.
Results 1 to 9 of 9
VOB usually is MPEG-2.
Nearly all apps that can read MPEG-2 .mpg files, can also read .vob files.
It seems you don't have to convert anything.
Maybe you could elaborate a bit on what you're trying to do here? -
I'm trying to get an XBOX 360 to stread a "VOB" file from my Mac Mini running Twonky media server. The XBOX 360 does pickup the AVI's I have and I know the VOB is good as I can view it locally via VLC and is fine (well a few performance issues) being streamed to a PS3.
Essentially I'm using the mac mini as a hub and xbox 360 & ps3 as display devices. -
Try VLC's Streaming/Export Wizard (File menu) to convert your VOB.
The issue with "where is progress.app" can be solved by browsing to the Application folder and selecting ffmpegx.Originally Posted by faxfan2002
This did the trick for me.
Kind regards,
Roebi -
As Case observed, ffmpegx doesn't seem to be required here. I'm willing to bet that simply renaming the file to .mpg from .vob will solve the problem, as pixel zombie suggested. If his streaming application balks for some reason, he could rip as a single vob, demux, then remux just the video and audio streams he wants. That ought to work.Originally Posted by Roebi
Thanks for all the suggestions! I'll work through them later - starting with remaning the file...
FFMpegX - NOT seeing VOB's imbedded subtitles...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 14th Jan 2012, 09:10 -
From ffmpegx: SRT+AVI=MPEG2; can't playback in anything.
By sclyman in forum ffmpegX general discussionReplies: 5Last Post: 12th Jul 2009, 18:31 -
encode a Keynote Quicktime movie to mpeg2 using ffmpegx possible?
By mkoehler in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2008, 09:16 -
single .vob in ffmpegX to h.264 (mencoder) .mp4 a/v sync issues
By jabroni5 in forum ffmpegX general discussionReplies: 15Last Post: 7th Jun 2007, 16:48 -
How do I make a muxed mpeg2 data file using ffmpegx?
By tjaca51 in forum Video ConversionReplies: 0Last Post: 13th May 2007, 23:20
