Hi, I have a Sony HC7 High Definition video camera and want to be able to back up the HD videos I have on it to a PC.
Is there a way to backup these HD videos to a PC?
thanks alot
You should be able to use the FireWire (1394A) connection for transfer. You do need a FireWire card or connection on your computer, along with a FireWire cable, usually mini 4 pin on the camera end and 6 pin on the computer end. Try WinDV to transfer the DV to your hard drive. If it's similar to standard DV, it will be about 13GB per hour of video.
Is your camera a HDR-HC7? If so I have the same camera and Personally, I'd just keep the tape as my backup and just capture off and edit, make discs etc., but I don't think that any storage media for backup is better than the Dv tape it's on right now. Even large servers etc. still use tape backup.
JMHO though
Cheers,
Max
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 20:16 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
