Hello everyone.
I have 30 photos that were scanned high resolution on my scanner. They are nice and clear. Now, I am posting on a site on INTERNET that requires small files. So I need to take these photos from high resolution (huge files) to a low resolution (tiny files).
Some of the photos are in color and others are in black and white. I want all the photos to be in low resolution and in black and white ..........but clear images - if possible. How do I do this? I don't want to go thru the mess of locating the original photos and re-scanning at a lower resolution.
Thank you.
Bryan Kendall
Thank you for your reply. I am sorry I don't have photoshop or anything similar.
But what is at irfanview? Where do I find it. Is it freeware?
Bryan Kendall -
The freeware Irfanview can also do batch conversions. That's how I convert photos for internet posting. It's under 'File>Batch Conversion/Rename'.You can set the format and the size and rename them all in one step. Click 'Advanced settings' in the 'Batch Conversion' menu for more setting options.
OK. I found irfanview. Thank you. Now how do I use this software for my images that were scanned high resolution from photos (huge files) to......................
a) Go from a color image to black and white image
b) Go from a high resolution image (huge file) to a low resolution image (small file)
I really am a klutz with this sort of thing. Could you give me a "how to do it for the complete idiot"? Assume my head is of wood.
Thank you.
bryan kendall -
Use the batch processing as described. In the Advanced menu there, check the 'Convert to greyscale' box for B+W conversion. Also click 'RESIZE' and enter the size you want. 640 X 480 is one choice. Or you can set by inches or CMs. You can also reduce the COLOR DEPTH if you want to make the file size smaller and leave them in color .....or not.
I change them from about one 1MB down to about 40K filesize. But 100K is probably better, depending on how big you want them for downloading or quicker display. -
Hello!
For me PhotoViewerPro 3.5.1 has been pretty usefull to increase the resolution of my pictures, It makes them look really sharp.
Capturing high-resolution photos from Blu-ray videos?
By Saxkat in forum Blu-ray RippingReplies: 3Last Post: 26th Dec 2009, 09:07 -
Photos off DVD video made of photos?
By 5chandlers in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 13:31 -
Low Quality on Dissolve Transition with Photos
By mattgx in forum EditingReplies: 22Last Post: 26th Jun 2009, 20:58 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
Correct resolution for photos for DVD?
By Grunberg in forum Authoring (DVD)Replies: 3Last Post: 13th Nov 2007, 12:41
