  1. Hello,
    I just installed the new version.
    When trying to encode, the programme asks me "Where is Process.app"?
    Is there something missing?
    My system:
    eMac 1,25 GHz PPC G4
    OS X.3.9
    Roebi
    Jan 2008
    Me too... on Mac Mini, 1.66, 10.4.11
  3. Strange, it should find it by itself. Also, I suppose the message says Progress.app, not Process.app. I didn't change this part since ages, so this error seem strange. Anyway, you may find Progress.app inside the ffmpegX application package (eg right-click or option-click the ffmpegX application icon, select "Show package contents", then go inside Contents/Resources, find the Progress application and launch it).
  4. Hello,
    I just tested this again.
    When I was asked where Progress.app was, I browsed to the Application folder and selected ffmpegx.
    This did the trick.
    The encoding is now running.
    Problem solved!
    Roebi
    Mar 2008
    This worked for me as well.
    Originally Posted by Roebi
    Hello,
    This did the trick.
    Problem solved!
    Roebi
  6. Thanks all.... I'll do the same (and yes, I was a dope and mis-typed "Progress.app")
    Carl
    Jul 2008
    Same prob here. And same solution. Thanks!
    No more g*dd*mn realmedia files for me!
